If it is Migged properly and then plannished and chemi treated for heat blue-ing from the weld then it should be damned near invisiblezero9243 wrote:I haven't looked too hard for welded tube just because i'm being picky, but it might be easier to find and then i could just turn it so the weld is on the inside.yamaha_george wrote:
Zero,
no tube except square LoL but rolled sheet & mig weld ?
Re: Zero9243's Rebuild (New Pics 11/16)
Yeah, i'll give it another try.cad600 wrote:e-bay. you would be surprised what you find there. do a general search for stainless steel then when the results pop up, go the left and narrow the search. you want to look in the industrial section under metals and alloys. i've gotten some titanium from there that was about 1/8 retail price. unfortunatly, i can't find anyone who can machine it.
Upgrades:
Man I can't find it on ebay. I don't even care about the wall thickness as long as i have a 3 3/8 inch inner diameter but no one seems to go over 3" on ebay. The reason i'm picky is because i need my endcaps to fit in perfectly.cad600 wrote:e-bay. you would be surprised what you find there. do a general search for stainless steel then when the results pop up, go the left and narrow the search. you want to look in the industrial section under metals and alloys. i've gotten some titanium from there that was about 1/8 retail price. unfortunatly, i can't find anyone who can machine it.
Upgrades:
Man I am quite the post whore. So any thoughts on where I can mount that radiator overflow?
Upgrades:
it depends how big it is .. are you using the stock one .. i ran mine along the inside of my subframe right next to my plastics and brake resevior .. i havnt had any problems or leaks in the 4 years since it's been reloacted ..zero9243 wrote:Man I am quite the post whore. So any thoughts on where I can mount that radiator overflow?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
whoops, sorry, guess I should have re-linkedPIMPMYFZR wrote:it depends how big it is .. are you using the stock one .. i ran mine along the inside of my subframe right next to my plastics and brake resevior .. i havnt had any problems or leaks in the 4 years since it's been reloacted ..zero9243 wrote:Man I am quite the post whore. So any thoughts on where I can mount that radiator overflow?
http://cgi.ebay.com/ebaymotors/_Car-Tru ... 240%3A1318
2" diameter and 10" length isn't that big is it?
No overflow will fit under the tail anymore as I have the custom passenger seat on the airtech tail as well as the VR relocated under the seat.
On the one hand i think this overflow would look cool, on the otherhand I want to minimize the accessories that are showing and try to hide everything. I want to just have the frame and fairings be obvious and keep everything else minimal. I want to try to hide the shock res to but we'll see
Upgrades:
Here is what the Honda AMA team does. If your still using only one head light, there should be room on the other side for a small bottle.
Love the idea. Cheap and hidden.cad600 wrote:Here is what the Honda AMA team does. If your still using only one head light, there should be room on the other side for a small bottle.
Upgrades:
- shredex
more pics!!!.....of what? I donno...are you going to do a new paint job also?
Yup. Frame, fairings, anything metal that I want to be flat black or silvershredex wrote:more pics!!!.....of what? I donno...are you going to do a new paint job also?
Upgrades:
Has anyone ever replaced the plexiglass in their gauge cluster?
Upgrades:
- shredex
never heard of doing that. its plausable if you can remove it...you just have to get some plexiglass cut the same wayzero9243 wrote:Has anyone ever replaced the plexiglass in their gauge cluster?
Yeah I can get plexi cut, the problem is removing the bastards. They look like they are in there pretty good, but i was thinking of baking them or putting a heat gun to them in the event that they might be glued inshredex wrote:never heard of doing that. its plausable if you can remove it...you just have to get some plexiglass cut the same wayzero9243 wrote:Has anyone ever replaced the plexiglass in their gauge cluster?
Upgrades:
WOO! Don't mind if i do! Picket up a barnett clutch for cheap
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0280510669
Upgrades:
and saved $7 w/ a paypal coupon codezero9243 wrote:WOO! Don't mind if i do! Picket up a barnett clutch for cheap
Upgrades:
