Moderators: Site Director , FZR Forum Moderators
YAM93
Posts: 1019 Joined: Sat May 17, 2008 8:19 pm
Post
by YAM93 » Thu Jul 24, 2008 8:21 pm
I have no idea on the line question, but I'd bet 95% of my money NYNOAH is right, I've never seen him be wrong.
That said, I'd say maybe there's a 5% chance it could be a HAGON ?????
zero9243
Level 8.5
Posts: 896 Joined: Wed May 28, 2008 3:23 pm
Post
by zero9243 » Thu Jul 24, 2008 8:42 pm
YAM93 wrote: I have no idea on the line question, but I'd bet 95% of my money NYNOAH is right, I've never seen him be wrong.
haha you're prob right. did you see how confident his post was? two words. no checking back to argue.
Upgrades:
Barnett Clutch------------------------------------------R6 Blue Dots, Front Master Brake Cylinder+Reservoir
ragedigital
4000+ Posts
Posts: 4153 Joined: Wed May 07, 2008 9:30 am
Post
by ragedigital » Thu Jul 24, 2008 9:19 pm
There is a guy who is replacing his Fox Shock with his rebuilt WP shock on his FZR400. He lives in St. Louis and I asked him to send a photo or check this thread to help us out.
darrin
zero9243
Level 8.5
Post
by zero9243 » Thu Jul 24, 2008 9:43 pm
ragedigital wrote: There is a guy who is replacing his Fox Shock with his rebuilt WP shock on his FZR400. He lives in St. Louis and I asked him to send a photo or check this thread to help us out.
darrin
Replacing a FOX with a WP! If that's what I have i'll be pretty happy!
Thanks for the help rage
Upgrades:
ragedigital
4000+ Posts
Post
by ragedigital » Thu Jul 24, 2008 11:00 pm
I think he's using the WP because it was recently rebuilt. You'll probably need to do that to yours soon.
To have someone rebuild it costs anywhere from $200+...
Not sure how happy that makes you.
haunter
Posts: 2266 Joined: Fri May 09, 2008 9:17 am
Post
by haunter » Thu Jul 24, 2008 11:01 pm
plus fox's are merely OK.
ragedigital
4000+ Posts
Post
by ragedigital » Thu Jul 24, 2008 11:07 pm
haunter wrote: plus fox's are merely OK.
Fox quit making them because the competition was getting much better reviews, so WP is probably better off the shelf.
However, irregardless of the shock, if your spring doesn't match your weight range, then you'll have a harder time getting it to work for you.
zero9243
Level 8.5
Post
by zero9243 » Thu Jul 24, 2008 11:42 pm
ragedigital wrote: haunter wrote: plus fox's are merely OK.
I figured as much. when i rebuild it (or get a rebuild) i'll have them give me a
spring for my weight range.
oh, and regardless what it is, it will be much better than our shitty stock shock.
Upgrades:
zero9243
Level 8.5
Post
by zero9243 » Fri Jul 25, 2008 12:13 am
Someone called the grammar police and I am here.
Irregardless is not a word!!!!
Upgrades:
Posts: 2026 Joined: Sun May 18, 2008 1:25 am
Post
by thatkid » Fri Jul 25, 2008 12:23 am
zero9243 wrote: ragedigital wrote: haunter wrote: plus fox's are merely OK.
zero9243
Level 8.5
Post
by zero9243 » Fri Jul 25, 2008 12:34 am
THE COMIC IS PERFECT
Upgrades:
abs929cbrrr
Posts: 1171 Joined: Sun May 11, 2008 12:53 pm
Post
by abs929cbrrr » Fri Jul 25, 2008 8:11 am
[quote="zero9243"][quote="ragedigital"][quote="haunter"]plus fox's are merely OK.
sounds fine to me...but then again i failed english class once.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
zero9243
Level 8.5
Post
by zero9243 » Wed Aug 13, 2008 7:43 am
WOO! Identified by a WP distributor in the UK as a 4681 WP "from the early 1990's"
Upgrades:
haunter
Post
by haunter » Wed Aug 13, 2008 8:18 am
zero9243 wrote: WOO! Identified by a WP distributor in the UK as a 4681 WP "from the early 1990's"
nice!
I'll give ya 20 bucks for it, WOrks shocks are awful thats why they are pink
