PM sentthatkid wrote:the_finch wrote:If you decide not to use them, I'll take the CFM Rearsets and steel clutch plates off your hands.
The CFM's I'll be hanging onto for a little bit. I'm on the fence of selling them or not. Make me a fair offer for the plates though and they are yours.
My new purchase. A plethora of parts!
- the_finch
- Level 8.5
Re: My new purchase. A plethora of parts!
1997 FZR600RJ
Well I was able to get it to run today and took it down the street. The carbs are severely jacked up. Won't start without choke and with choke it revs to like 6k once I pull the clutch in after it's moving. I got it to idle at around 2k but it was a hunting idle, not steady. Also wouldn't even register on the carb sync tool. I cleaned the crap out of the carbs so I'm not sure what's up. Any ideas?
idk, maybe try throwing a stock airbox on? I guess it could be something goofy like that. you adjusted the idle and everything i'm guessing.
Upgrades:
id throw an airbox on it and return the carbs to as stock of settings as possible and go from there
SOLD
SOLD
what is this? a parrot?!!haunter wrote:id throw an airbox on it and return the carbs to as stock of settings as possible and go from there
Upgrades:
squak! haunter wants a cracker! squaaaaaaak!zero9243 wrote:
what is this? a parrot?!!![]()
SOLD
SOLD
*gives haunter a cracker and a noogie*
Upgrades:
