I think Im going Fighter
mrfreeze5
Level 8.0
Level 8.0
Re: I think Im going Fighter
Post by mrfreeze5 »
Actually thats pretty close to my list. But the electrosport speedo/tach/light unit has already been set up wiring wise. I had to make a custom harness basically. If I do it streetfighter Im only going to use the speedo(it has a small tach on it) and then put the big tach on later. I think Im just going to get it running right now and ride as is for a little while just so I can ride. Then I ca put the other stuff on later. Like you said, cosmetics come last.
Fizzinatorr
Level 6.5
Level 6.5
Post by Fizzinatorr »
mrfreeze5 wrote:Actually thats pretty close to my list. But the electrosport speedo/tach/light unit has already been set up wiring wise. I had to make a custom harness basically. If I do it streetfighter Im only going to use the speedo(it has a small tach on it) and then put the big tach on later. I think Im just going to get it running right now and ride as is for a little while just so I can ride. Then I ca put the other stuff on later. Like you said, cosmetics come last.
Genius. Good luck Freeze :) :cheers:
and don't forget you still have to build my FZR/2001 R6...you can fighter that one if you want :puke:
abs929cbrrr
Post by abs929cbrrr »
i think your bike will look better naked...forsome reason i didntlike seeing it with fairings on. buell headlights?
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
csofos
Level 4.5
Level 4.5
Post by csofos »
Well, take a look of my fzr 400 to get some ideas. I don't know if i'll help. Image
