95FZR600 wrote:Hey racedigital, that is the cleanest subframe and tail I have ever seen on an FZR. Makes me want to go gut mine and paint it. Great job on the tail by the way.
Well, thank you for the compliment!
Yes and yes. I cut some length from the undertail. Probably about 7". When I find the pic, I'll post it.PIMPMYFZR wrote:im tempted to try this out .. now the undertail .. did u have to cut anythng from it or the underside of the airtech tail?
I used a hand grinder to do a lot of the cutting. I also used my Rotozip with different bits on it. Yes, you will have to do quite a bit of glass work to get it to shape to the tail light. I would definitely do it again. Wasn't too hard.PIMPMYFZR wrote:what did u use to cut the Airtech tail with ? and did u have to glass anything or reshape as far as where the taillight fits and meets the tailend ?
I have the updated VR and so mine is under the tail. Doesn't get much airflow, so it is a bit of a concern. I'm thinking about putting my CPU fan on it.PIMPMYFZR wrote:the VR HAS to be moved ? will it work in stock setting or i take it the undertail wont fit .
