Project "Never satisfied" - A very British rebuild!
Fartblood
Level 4.5
Level 4.5
Re: Project "Never satisfied" - A very British rebuild!
Post by Fartblood »
Right, much has happened in my 2 month computerless enforced absence.
A host of small brackets, footpegs etc painted - you don't realise how may tiny components there are 'til you've decided to refurbish or replace every last nut and bolt!
I've also pulled my finger out and painted my garage walls and floor, which slowed things down a bit but makes working out there so much nicer.
Work has started prepping the frame itself and I'm hoping to be able to apply paint soon. More pics to follow!
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
Not much happened of late, and I'm now recuperating following a 2nd operation on my arm.
Frame is now prepped and ready for painting. I hope to have a pic up for you in the next few days.
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
The frame etch primed, red oxide primed, filler primed, and hi-build primed as required, then rubbed down...
And the frame painted...
Despite wearing a mask, I'm rather stoned from inhaling 3 cans of PJ1's finest frame paint!
Gonna let it dry for a few weeks, then some fun ahead rubbing it down and polishing it up to the final finish.
Yamster
Donating Member
Donating Member
Post by Yamster »
Nice work there FB.
Now yer arms better mate,look forward to seeing the bike come along. :thumbsup:
Got my"Cadbury,s boost" one to start next,dont think i should set a completion date till 2011. :dubious:
FB,
Glad you are still at it thought you were all healed up and busy beavering away at the "work" did not realise you were still crook or i would be up to scoff yer grapes.:-}
Give yeh a bell and pick up that stuff (9,10,11th are possibles ) now I know yer still skiving <BG>
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
Yeah, i'm stuck at home for at least another couple of weeks yet Geo.
Right, I've figured out how to change the fork seals without dismantling the forks, so they'll be painted and new seals fitted next.
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
EXTREME CLOSE UP! I don't think I mentioned, but I also filled the recesses in the main frame rails for a nice smooth look:
Here's a fork with new springs, new seals and rubbed down and repainted. Second fork is currently in progress:
And here's a front mudguard/fender mounting bolt thingy. The Devil's in the detail!:
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
More pics to come soon - just rebuilding and repainting the front calipers.
Post by sweekster »
Smoothed the frame. Well then. I'd say check mate...mate.
Fartblood wrote:More pics to come soon - just rebuilding and repainting the front calipers.
FB,
You really must be bored Sh@tless if you are frame filling, new springs ? did you use PD Valves (aka Emulators) ?
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
Can't even remember the make of the springs...Maxton? Max something. Just progressive springs. I was never that unhappy with the front end and always had the size and strength to chuck it in quite well - it was the way the back end sometimes failed to follow that used to s*** me up!
Yeah, filling the recesses in the frame rails seemed a good idea at the time, but several days into it things started to pall. Don't arf look good now it's done though.
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
Front calipers, stripped, new seals (pistons were unmarked), new bleed nipples and banjo bolts, new pads, new paint...
dougs
Post by dougs »
fantastic work love it
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
R6 lever mountings with short adjustable levers
YZF600R (thundercat) rear adjustable shock
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
