There were a couple scrapes in the top I filled in. Once it gets powdercoated you'll never know.
They only come cleaner from the factory!
Same issue...a few scrapes all filled in. Has since been sanded down but forgot to take a picture of it.
Rotors got painted for the 600 frame for when I sell it. Color scheme is changing to black/anodized blue/silver as it's more popular and should make the bike easier to sell.
Rear Brembo got stripped of paint and is on its way to get powdercoated. It will probably be for sale and setup so it will be a direct bolt on for the FZR. I may bundle it with a powdercoated loaded rear caliper and brake arm/mount etc. Basically a whole rear brake assembly.
The top clamp. It is a deeper blue but the flash takes away the true color. I'll get some better pictures when I have sunlight.
And then the pride and joy.. It will be getting powdercoated so you'll never know there was filler there. The guy I used pulled the dents out as far as he could and then used filler to smooth it up before it goes to get coated. And smooth it is. Now this frame is truly in excellent condition.
Eventually I will start a rebuild thread for the 400 frame but for now there just isn't enough to start one.
