AMA toys???
AMA toys???
Messing around with photoshop. Thought this was a cool effect
Upgrades:
- megaloxana
- 2000+ Posts
Re: motogp toys???
looks like its miniture scale. You know kinda like those train set towns people build.
'92 FZR 600
Re: AMA toys???
whoa, so that's a real life image made to look like a diorama? that's awesome! how'd you get that effect?
Thanks, for a country where nobody is allowed to mind his own business. Thanks, for a nation of finks.
- William Burroughs
haha this is awesome... probably the only addiction support group i have seen that supports the addiction!
Last words are for fools who haven't said enough.
- Karl Marx
- William Burroughs
- Karl Marx
Re: AMA toys???
U want a higher resolution version? send me your email.slayermd wrote:I like it. it is now my wallpaper.
Upgrades:
- ShogunTX
- Level 4.5
Re: AMA toys???
Hey thats really neat, so are you going to divulge the secret?
Re: AMA toys???
You should be able to do it with a radial blur.ShogunTX wrote:Hey thats really neat, so are you going to divulge the secret?
Re: AMA toys???
What you wanna do is in photoshop select the gradient tool. Then you choose the fourth option for gradient which kind of looks like a cylinder. Then you press q to go into quick mask mode and click and hold where you want the focus point and drag away. Then press q and go to filer>lens blur. Make sure invert is selected and then it should give you a good preview of what it will look like after the blur is applied.
Upgrades:
