inside of a running 4 stroke engine *video*
Upgrades:
- megaloxana
- 2000+ Posts
Re: inside of a running 4 stroke engine *video*
Thats awesome. Not as hostile as I thought it would be.
'92 FZR 600
That was definitely pretty cool.
Do YOU Scopper?
nice find. that must be slow-motion.
i would like to see that faster but it was a great find
Heh, well at 1000 frames per second, the have A LOT of frames to show.YAM93 wrote:nice find. that must be slow-motion.
Do YOU Scopper?
- mike94fzr600
- Level 4.5
Thats awesome
my rides
2000 chevy z71 4x4
1993 Suzuki Samurai my mud \ trail toy
1994 fzr 600
2000 chevy z71 4x4
1994 fzr 600
Damn thats krazY.. so when i start my bike thats what it looks like in there ?
i watched the whole video , but still dont get how everything comes together ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
That is pretty cool. Nice find.
Valve opens, gas and air come in through valve, piston comes up, spark plug sparks and ignites gas and air, explosion pushes piston down, exhaust exits through other valve.PIMPMYFZR wrote:Damn thats krazY.. so when i start my bike thats what it looks like in there ?
Rinse, Repeat
Upgrades:
ahhh im getting a picture in my head so there really is an explosion going on in my engine then so when u open the trottle all the way it does it but alot faster or same rate ?
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
- ShogunTX
- Level 4.5
- Suck
- Push
- Bang
- Blow
- ShogunTX
- Level 4.5
It isn't really an explosion as it is a "Controlled Burn" the video does a good job depicting the burn.PIMPMYFZR wrote:ahhh im getting a picture in my head so there really is an explosion going on in my engine then so when u open the trottle all the way it does it but alot faster or same rate ?
If you have an explosion you have Detonation and that is an undesirable burn
If it ignites before it's suppose to then you have Preignition also an undesirable burn
Ideally you will have a spark that sets the compressed air/fuel mixture on fire and it is a smooth and even burn of the mixture.
Yamaha_George can probably give a in depth explanation but the concept is the same for all internal combustion engines. Rotary engines are an entirely different contraption.
