Has two new tires on it that do not have 50 miles on them, they are not cracked or old and rotted, tney are perfect, mounted and balanced by a good shop. Needs a new keyswitch but will start and run.
If you look at my history on here.... i bought it for 800 and put 260 dollars worth of tires on it and there you have it.
It even comes with an extra frame , no subframe.
It has a supertrapp full exhaust and runs without a hiccup when the carbs are clean, i havent started it in 6 months and im praying they are not gummed up. Needs battery also.
I have the fairings, they are cracked in places. The front fairing is not perfect but cracked on sides. The tires in this pic are gone, replaced.
