Thanks in advance!
well im learning the more im looking at them, had a wee look at everything and it seems honky dorey, it's wierd it sounds like its revving really high but the rev counters only showing 3k rpm, its bogging down big style when you give it full throttle and its stinking of fuel so i guess i need to sort out a way to lean it out a wee bit, sounds miles healthier now though.SouthendChris wrote:Its more than likely that somewhere in all the tubes you cant see there will be some petrol thats gone solid and is blocking something up. If I was in your shoes I would take the carbs off in one big lump. Take the diaphragms out. Then give the rest to someone with an ultrasonic carb cleaning bath. Do this before you make any adjustments. What you are doing is probably trying to make up for a couple of blocked pilot jets or emulsion tubes. Get em cleaned and try them again - then start adjusting them!
oh andof your bike
Chris
