Cdi Compalibilty Questions
I have a 1994 Fzr 600 I was wondering If a 1989 fzr 400 cdi would work on my bike they seem to have the same pin count but I wasn't sure. I would appreciate any imput I'm also looking for a cdi (if this one dosnt work out ) so if you got a spare let me I is I'll take it off your hands for you.
Donald Purple 1994 FZR 600r (streetfighter)
Re: Cdi Compalibilty Questions
The 400 TCI (not CDI) will work with the 600 engine. The problem is, it may work TOO WELL - the 600 TCI limits the spark just past 11500 (IIRC), while the 400 TCI will allow the engine to scream up past 14000 - listen for the crunch! of an ingested valve ... The mechanical redline of the 600 engine is higher than 11500; the V&H PowerPak ignitions take advantage of this. It is, however, rather less than 14k.
Sorry if you received my other pm's (the message system is not working for me i didnt mean to bother you with to many messages).DonTZ125 wrote:The 400 TCI (not CDI) will work with the 600 engine. The problem is, it may work TOO WELL - the 600 TCI limits the spark just past 11500 (IIRC), while the 400 TCI will allow the engine to scream up past 14000 - listen for the crunch! of an ingested valve ... The mechanical redline of the 600 engine is higher than 11500; the V&H PowerPak ignitions take advantage of this. It is, however, rather less than 14k.
I would really like to be riding again so Do you sell TCI's? if so how much ? I will send you my old TCI (my dad and i tried to play technician) so if it cant be repaired i would like to donate it to your cause. Lastly what would be faster a repair or just buying one out right please let me know soon. Waiting for a ride SUCKS!
