Does the Engine Flush solutions affect the r&c?
Posted: Thu Feb 09, 2012 7:12 pm
by cs_05_hho
Hello there guys! I have a question for you all - does the Engine Flush solutions affect the rotor of the alternator and the clutch plates? I've seen a LiquiMoly engine flush agent that has a warning on it - don't use on wet clutch motorcycles!
I wasn't planning on using such an agent - but I just had to ask to know if someone done the same thing and what were the repercussions!?
Re: Does the Engine Flush solutions affect the r&c?
Posted: Thu Feb 09, 2012 7:30 pm
by cs_05_hho
I've discovered this on e-bay Wurth Motorcycle Engine Flush and Cleaner 300ml...
Posted: Thu Feb 09, 2012 9:41 pm
It won't do anything to the rotor, but it's bad practice even to use car oil with "energy conserving" additives. Any super-duper moly slip additive will ruin your friction plates.
Posted: Thu Feb 09, 2012 10:03 pm
by FZRDave91
Posted: Fri Feb 10, 2012 4:53 am
by cs_05_hho
I didn't mention anything about using car oils!
Posted: Fri Feb 10, 2012 8:41 am
by ragedigital
cs_05_hho wrote:...does the Engine Flush solutions affect the rotor of the alternator and the clutch plates? I've seen a LiquiMoly engine flush agent that has a warning on it - don't use on wet clutch motorcycles!
The rotor is dry.
I didn't see the warning on the Flush Tech Sheet for the LiquiMoly, but I did for their other additives.
We use SeaFoam a lot here in the states as an Engine Flush with very good results.
cs_05_hho wrote:I didn't mention anything about using car oils!
When someone mentions "Moly" products and says that they're not safe for wet clutch motorcycles, then it means that there are additives, like what "car oil" has, that will make the clutch slip.
