Does the Engine Flush solutions affect the r&c?
cs_05_hho
Post by cs_05_hho »
Hello there guys! I have a question for you all - does the Engine Flush solutions affect the rotor of the alternator and the clutch plates? I've seen a LiquiMoly engine flush agent that has a warning on it - don't use on wet clutch motorcycles!
I wasn't planning on using such an agent - but I just had to ask to know if someone done the same thing and what were the repercussions!?
cs_05_hho
Re: Does the Engine Flush solutions affect the r&c?
Post by cs_05_hho »
I've discovered this on e-bay Wurth Motorcycle Engine Flush and Cleaner 300ml...
It won't do anything to the rotor, but it's bad practice even to use car oil with "energy conserving" additives. Any super-duper moly slip additive will ruin your friction plates.
FZRDave91
Post by FZRDave91 »
Agreed
What he said
1991 FZR600 w/ YZF VR Upgrade, Twin Headlight conversion
1981 XS400 Cafe build.
Can't ya tell I like Yamahas?
cs_05_hho
Post by cs_05_hho »
I didn't mention anything about using car oils!
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
cs_05_hho wrote:...does the Engine Flush solutions affect the rotor of the alternator and the clutch plates? I've seen a LiquiMoly engine flush agent that has a warning on it - don't use on wet clutch motorcycles!
The rotor is dry.
I didn't see the warning on the Flush Tech Sheet for the LiquiMoly, but I did for their other additives.
We use SeaFoam a lot here in the states as an Engine Flush with very good results.
cs_05_hho wrote:I didn't mention anything about using car oils!
When someone mentions "Moly" products and says that they're not safe for wet clutch motorcycles, then it means that there are additives, like what "car oil" has, that will make the clutch slip.
