Dimension help for !k swing arms
well the 1K swing arm bolt in has been rubbished,but since a lot of you dead jealous of Tony's fat rear end, perhaps it is time to start breaking down what is required to do this mod right.
We now think that the 1K swing arm is 241.3mm across the pivot end
(still puzzles me as to why such an odd number even for Yamaha )
we also know for a fact that 600's & 400's have a frame throat that accepts 220mm
What we need to KNOW is how much each end of the pivot material was removed from each side so that
A} the chain lines up straight
B} the wheel sits in the frame on the center line
Re: Dimension help for !k swing arms
what we need george is a 1k swinger sent to me free of charge and i will take measurements pictures of both ,i will strip down and take picks and measure all spacers and all that is needed for this swap this may be the best way as i will have the stock 1k swinger to compare with
- trifgeorge
OK.... I've got some info about the 1992 fzr 1000 swingarm and wheel.
A) width of the inside of the swingarm where the wheel's axle gets in is 267 mm.
B) width of the wheel with sproket carier on, from bearing to bearing is 210 mm.
C) each side wheel spacer's width is 13 mm.
D) caliper bracket's width is 27-28 mm.
E) A)+B)+C)+D) = 264 mm.
F) A)- E) = 3mm (calculated error by Yamaha so you can slide the whole wheel assembly in)
I did all these measurements on a 1992 fzr 1000 that i have in my garage.
I am also thinking about a mod i could do to my stock 600 swing arm to slide a fzr 1000 wheel in. I will post a scheme of what i intend to do.
1992 Yamaha FZR 600 3HE with:
Sigma BC 1009 speedometer
YZF 600 Thundercat tank
Red Rizoma like grips
R6 pilot seat
R6 Voltage regulator
Custom made rearset hangers
KOSO mirrors
FZR1000 hydraulic clutch
H1 HID
Hand made mirror plates
R6 pilot seat
KOSO mirrors
H1 HID
Thanks George from the other one :-}
TG, what we need also is:-
G} the width of the pivot point with dust covers on and with them off,
H} pivot bolt diameter
J} pivot bolt sleeve diameters(inner & outer) & length
K] length of pivot bolt centre to centre of rear axle when at mid adjustment of chain.
PUT the info under 92 FZR 1K in the WIKI
- trifgeorge
that info i do not know for sure if i can provide, as the bike is not mine and i do now wish to take the swingarm off without letting the owner know first before i do it. i'll do my best!
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
- trifgeorge
ok. L.E. damn, the pictures are updated upside down! the second got first and the first got second. u get the idea!
- Attachments
- in the second picture is where i want to make my cuts in the original swing arm (light green color) and where i want to position another 600's swingarm arms next to the cut ones so that the width at the axle of the wheel shall be 267 mm, and that the brake disc, wheel, and sprocket will not rub on the swingarm anymore when the chain is new.
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
- trifgeorge
i must disagree with you Tony. the non modified fzr 1000 swinger has 42 mm on each side of the wheel (measured from the 180/50/17 tyre to the swinger). in this picture, the arrows show where i did the measurements. i can guarantee for these measurement with my head.
. these measurements proove that there is no designed offset in the swingarm.
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
sorry trig you mis read i said the 600 swinger has the offset the 1k we know is equal as this is maybe why the chains alignes with my swap
- trifgeorge
you are correct. i appologise ! i missunderstood what you said. i guess i'm not as good at english as i think i am
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
Your English is a lot better than my Romanian...
- trifgeorge
R6 pilot seat
KOSO mirrors
H1 HID
R6 pilot seat
KOSO mirrors
H1 HID
ok guys i took1k swinger back off the pivot bolt and sleeve are stock 600 parts as in pics
