will it fit
Posted: Fri Oct 15, 2010 3:31 am
by FZR AL
Hi all
does anyone know if a predetor end can Fzr600 3he 93 model would fit a Fzr600 3he 89/90 model is it a straight swap or is there any modification required
cheers al
Re: will it fit
Posted: Fri Oct 15, 2010 6:17 am
by cad600
I would think it would fit given the PO had not modified anything to his bike. I don't think Yamaha ever changed the header for these bikes besides the EXUP valve. Even then, I don't think the physical size changed.
Re: will it fit
Posted: Fri Oct 15, 2010 7:24 am
by thatkid
Unless the PO had after market headers fitted (different diameter end can?). Ask the seller to measure the internal diameter of the can.
In this situation I always check the parts fiche and compare the part numbers of the 2 years in question.
http://www.cmsnl.com/yamaha-fzr600w-198 ... /B-09.html
3HH1471000
MUFFLER ASSY 1
http://www.cmsnl.com/yamaha-fzr600re-19 ... /B-09.html
3HH1471010
(3HH-14710-11) MUFFLER ASSY 1
Note: this part is superseded by 3HH1471011.
Although the numbers differ, take a look at the pic's. The only difference between the mufflers appears to be a heat shield (upgrade/modification?), also a complete system is the same part number for both years.
3HE1460200
EXHAUST PIPE COMP.
Hope that helps.
