520 conversion...
520 conversion...
I'm wondering if the 520 coversion is worth doing, is it very noticeable on the acceleration? can someone fill me in on the info on this for those who have done... thanks
Edit: nevermind, i just read about it on the vortex page on ebay, but for those that have done it and would like to express their opinions on it please do
Wichita, KS
95' FZR600
88' FZR400 with YZF 600 Motor
yahoo msg: swingline1021
95' FZR600
- kilika2
- 1000+ Posts
Re: 520 conversion...
Just did it last week. www.sumofallparts.com
129 free shipping. In hind sight I would have spent the extra money for the ptfe coated sprocket.
AMAZING DIFFERENCE. Also just so anyone that wants to know. I gained about 1000 k in every gear and only lost about 4 mpg. I opted for the 14/49
Chris.
Also there is a guy selling a 14/47 sprocket set on here, no chain but you would probably save a lot of money. gogofizzpow I think is his name.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
I did the 520 conversion as well, but went with 14/45.
I love it. It didn't kill the mileage at all, and I only gained about 500 rpm in each gear. The slightly better acceleration is from the gearing, and the smoother running I feel like I can attribute to the newer chain. (the old one was well on it's way out)
- kilika2
- 1000+ Posts
+234598734523 on that one. No more jerking at lower rpm with engine decelleration.olie05 wrote: and the smoother running I feel like I can attribute to the newer chain
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
I did the 14/49 and the difference was huge. The smile on my face after installing was priceless.
does it wheelie any easier? and does the 14/49 come in a kit? i can only find 14/47 which is vortex with chain and both sprockets...id like the kit to the 14/49
Wichita, KS
95' FZR600
95' FZR600
- kilika2
- 1000+ Posts
Second. If you go to sum of all parts and select your bike you can get whatever size sprockets you want. As for wheelies.... Probably, I can't do wheelies. To chicken.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
I was the local wheelie king (in the 80s) I don't have the reactions/nor balls anymore plus I'm a safety freak nowkilika2 wrote:Second. If you go to sum of all parts and select your bike you can get whatever size sprockets you want. As for wheelies.... Probably, I can't do wheelies. To chicken.
Chris.
I want one of those 520 kits from sumofallparts, but it dont list 90 fzr 400
. When you go to a 520 conversion, what is the difference in teeth from a 530, my rear sprocket stock is 55 teeth, what would that be in a 520 ?
520 is the width of the chain. If you use a 520 chain, you have to use 520 sprockets.
Right, but if my 530 stock sprocket has 55 teeth, and i now want a 520 sprocket, does the teeth count stay the same ?. 530 55 teeth stock, = 520 sprocket teeth ???ragedigital wrote:520 is the width of the chain. If you use a 520 chain, you have to use 520 sprockets.
Only difference is the roller width / sprocket thickness.
A 55 tooth is stock on a 400? That sounds awfully big.
Check this link part 14, is a 55 teeth stock sprocket. I cant even find a 55 tooth 520 sprocket, so something teeth wise must change when you go to a 520. http://www.mrcycles.com/fiche_section_d ... 0&fveh=370.
Your 400 should have a 428 chain(smaller than a 520). This is why you have a 55 tooth rear.Fzrmike33 wrote:I want one of those 520 kits from sumofallparts, but it dont list 90 fzr 400 . When you go to a 520 conversion, what is the difference in teeth from a 530, my rear sprocket stock is 55 teeth, what would that be in a 520 ?
Going to 520 on a 400 would be a performance DEgrade
