Yzf front end swap help
Got a yzf 600 front end upgrade put on my Fzr600. Forks brakes tire. First speedo was off by 10 I have stock Fzr cable on it. Then I switched just the cable to the yzf one like just the inside metal spinning part and it put it off even more then just stopped working. I need a fix soon before I get a ticket thanks
Re: Yzf front end swap help
is it off high or off low it seems the only different from before and after is the speedo gear at the wheel around the axel. i think i heard they are the same ratio so it should be correct id check there.
its low... but i tryed to switch the fzr and yzf one the yzf is bigger for there wider axle.
