need info asap on a rear wheel im buying
so lads iv got my eye on a rear wheel thats of a tzr250 but i dont tink it comes with spindle or disc or anything so im just askin wether my disc and spindle will fit it and is it worth my buying it for £59? could do with knowin asap please fellas. o and i have been offerd a rear wheel thats a 17 but its ofthe 400 3tj will that fit any better? thanks
China_Racer_1
- Level 5.0
Re: need info asap on a rear wheel im buying
I am pretty sure I have a rear wheel spindle right here I can send you for free & postage. I had a TZR and found a few things like that you can have it all.
Spacers spindle I am not sure what else. Maybe even the rear brake mount on the disc side. I might have a disc..... maybe not. Have to look in the TZR box.
What size is the wheel 17" x ? wide? I thought it was 4.25 wide.
What size is the 3TJ? 17 X ? Wide
If the same I say go with the 3TJ as it most likely will have a few more simular/compatable parts. But then maybe they all ar interchangeable. Sorry I guess not much help really. If you go with a TZR set up PM me with an address and I will see hat all I have and how much to send it to you.
- the_finch
- Level 8.5
You could make almost anything work, but the largest wheel that will fit in the FZR600/FZR400 (non-3TJ) is a 17x4.5. If it's 5 or 5.5 wide it won't fit without a swingarm swap, at which point you're probably best off going with a Foxeye FZR600R (YZF600 in the states) swingarm and wheel swap.
1997 FZR600RJ
I think the old man already covered that on his web site under FZR projectfzrwayne wrote:so lads iv got my eye on a rear wheel thats of a tzr250 but i dont tink it comes with spindle or disc or anything so im just askin wether my disc and spindle will fit it and is it worth my buying it for £59? could do with knowin asap please fellas. o and i have been offerd a rear wheel thats a 17 but its ofthe 400 3tj will that fit any better? thanks
