Page 1 of 3
Making a Fork preload adjuster caps set -interested?
Posted: Mon Jan 04, 2010 4:10 am
by fzrbrandon
Just trying to gauge interest in these to see if it would be worth the time to have them designed and made...
Re: Fork preload adjuster caps
Posted: Mon Jan 04, 2010 11:48 am
fzrbrandon wrote:Just trying to gauge interest in these to see if it would be worth the time to have them designed and made...
Brandon,
In this age, I would say that would be dependant on cost at 150 a pair not likely but at 50 and below I would say they would sell.
Might I suggest you get a good design and then you submit that to the list so not only can you get a local quote but us furriners might take a look by them to and see what is cost efffective for the group. China-racer Steve has some good contacts as do I and a couple of others here
Posted: Mon Jan 04, 2010 12:26 pm
by thatkid
yamaha_george wrote:fzrbrandon wrote:Just trying to gauge interest in these to see if it would be worth the time to have them designed and made...
Brandon,
Geo,
I'd be making them. We are looking for the most simple design so I can actually get them to production. Brandon has the JEM adjusters and would be taking them off the bike to get me measurements and pictures. Just seeing if it's worth the time. I think I could keep it in the 75 range depending on design and what has to be done.
Posted: Mon Jan 04, 2010 12:55 pm
by Fartblood
If you could get 'em to my door in Englandistan for $100 then deffo, though would consider it still if a little more.
Posted: Mon Jan 04, 2010 1:26 pm
by fzrbrandon
thatkid wrote:yamaha_george wrote:fzrbrandon wrote:Just trying to gauge interest in these to see if it would be worth the time to have them designed and made...
Brandon,
Geo,
Yep, What TK said.
A LOT of guys have been asking about these things lately so obviously the more interest there is, the lower the potential cost can be.
Posted: Mon Jan 04, 2010 10:19 pm
by markd
At 75 a set I would definitely take a set!
Posted: Wed Jan 06, 2010 2:53 am
by fzrbrandon
Bump. I could have sworn more guys were wanting these
Posted: Wed Jan 06, 2010 8:45 am
fzrbrandon wrote:Bump. I could have sworn more guys were wanting these
B,
you may have been right late last year but this is AFTER christmas when every male I know is complaining of being hung over & / or broke.
I would still like to see the design before they are made ..................
Posted: Wed Jan 06, 2010 8:56 am
by cad600
I'm sure there are others out there who are interested. They probably have the same issue I do being this is the first time I've seen this thread even though it has been up since Monday. Try changing the title of the thread. Maybe people won't skip over it then.
As for the question, I'm not going to vote because I don't want to skew the results. My personal discission is to swap forks instead.
Re: Making a Fork preload adjuster caps set -interested?
Posted: Wed Jan 06, 2010 9:58 am
by Yamster
I would like some,but as George says,its the money ATM for me.Put me down for a set if you can hold onto them for a little while.
Posted: Wed Jan 06, 2010 1:13 pm
by fzrbrandon
cad600 wrote:Try changing the title of the thread. Maybe people won't skip over it then.
LOL! I thought the thread subject line looked different!
Posted: Wed Jan 06, 2010 1:21 pm
by fzrbrandon
yamaha_george wrote:fzrbrandon wrote:Bump. I could have sworn more guys were wanting these
B,
Yeah, I get what you're saying. However, I figure if someone is showing interest in purchasing something it means they've probably got the money to spend on it. It's not like Christmas was a big surprise or anything! LOL! Anyway, I just want to make sure there's enough interest in this before I pull mine off and go through the trouble of taking pics and taking measurements. If I do it, I want to do it right so Nate has some decent "blueprints" to base his design on. It wouldn't be a "scratch it out on a paper-napkin" kind of thing. Also, I'm sure he would like there to be a good number of solid "Yes, I want them" replies before he goes through the trouble. Nice little Catch-22, eh?
Posted: Wed Jan 06, 2010 1:40 pm
by thatkid
Well I worked on a set last night. Needed to go to the shop anyway. I have the design down, but it's getting it right with my semi retarded lathe. They are going to be a simple 4 piece design. Bolt, cap, block, and o-ring. I will need original fork caps in order to modify them for this endeavor. I have a few sets of spares so if people are interested in this, just so you know in advance, it would be a core exchange type of deal. I'll send you an all ready to go one but I'll need your fork caps back. If I do it this way I can do it much cheaper for you guys.
My first one was a slight fail as I mixed some measurements in my head but it's a very simple fix. I have everything in my shop to do it pretty much. The bolts I'm using are a 13 threads per inch instead of the 20 per inch the model I'm using uses. I don't mind changing that but I can't find any local with a higher tpi. I don't think anyone will miss it much. You'll still have over an inch of preload adjust.
I'm really trying to come in at ~75 for you guys to make these affordable. I'm modeling them off a lockhart quik-adjust that a friend had on their forks. I'd still like to see the JEM brandon, but if you don't get around to it no worries.
I'm thinking there will be the option to mix and match colors for powder for an additional fee. Otherwise they will all probably be black. I'll post some pictures up a little later.
Posted: Wed Jan 06, 2010 3:30 pm
by fzrbrandon
Dude! You rock! That was really quick. Glad you found a set to use as a model. You've now inspired me to get off my arse and do my part! LOL! I'm heading out to the garage in a little bit here so I take some pics while I'm out there. I'm helping MarkD with some fork stuff so it probably won't be until early evening that I can get them put up.
Brandon
Posted: Wed Jan 06, 2010 4:16 pm
by the_finch
If they're in the $75 range you can count my "Probably So" answer to a "Definitely Yes"
