http://www.weldingtipsandtricks.com/
http://www.weldingtipsandtricks.com/ama ... eatin.html
welding for Nubes site
Re: welding for Nubes site
look mam no hood now iv got flash cant sleep or open my eyes yep and forget sun light
I admit he does seem a bit macho / cavalier about some things but i figure that any one who reads it knows enough to use the helmet / goggles.KASH wrote:look mam no hood now iv got flash cant sleep or open my eyes yep and forget sun light
'cides one dose of "arc eye" will cure most people of such rashness.
- the_finch
- Level 8.5
+1yamaha_george wrote:I admit he does seem a bit macho / cavalier about some things but i figure that any one who reads it knows enough to use the helmet / goggles.KASH wrote:look mam no hood now iv got flash cant sleep or open my eyes yep and forget sun light
We had a welder here at my work years ago who was just closing his evey when doing a tack weld with a mig welder. He forgot to close his eyes one time and wound up having to have his corneas scraped.
Needless to say he used a welding hood from there on out.
1997 FZR600RJ
Yep, and teach this un-humble servant that when the old timers tell you to lose the auto-shade helmet and get a fixed shade, a person should listen. Arc-eye sucks.yamaha_george wrote:I admit he does seem a bit macho / cavalier about some things but i figure that any one who reads it knows enough to use the helmet / goggles.
The guy's site is pretty good. Lots of 'field tested' stuff. I like how he hammers home that you need to learn uphand MIG for anything decently thick. A man can/will get fired at my shop for running downhand on anything over 11 guage.
Here's some photos of my latest D1.1 structural steel certification coupons. I have been laid off long enough (more than 6 months) that my certs needed to be updated. I ran coupons in 3g (vertical uphand GMAW{MIG}) and 4g (overhead-upside down-GMAW). The process itself is certified by our shops WPS (weld procedure specifications-includes voltage, wire, wire speed, gas and material)
This is a 3/8" steel(a36) groove weld, done with .045" e70-s6 flux cored wire. The groove is 1/4" wide, 37.5° bevel(with backer bar). It is a root weld, and then a 'fill pass' and then a cover pass. The cover cannot exceed 5/8" wide and 1/8" high. It was 7" long. The face pass and the root pass are sawn off from below and above the visual inspection section, sanded flat and then bent in a press(one to stretch the face, one to stretch the root) to expose any flaws. You can see in my 3g root there are a couple of inclusions, but they are under the total allowance by 3/32" (none can be OVER 1/32" and there is a total factor as well). Inclusions are allowed on root, but not internal, or face pass.
3g showing cross section:
4g (overhead):
4g showing cross-section:
