dyno jet performance kit stage 1
3LK1-FZR
Post by 3LK1-FZR »
has any body here used one? any noticable results? im thinking about installing it on my FZR 1K but want a few opinions first.
1989 FZR 1000 with an 01 R1 front end. k&n filters, vance & hines exhuast. currently down for a new face lift.
i once raced a guy on a R1 with my RD 400. i beat him through the intersection, after that it wasnt a race...it was puplic humiliation
zero9243
Level 8.5
Level 8.5
Re: dyno jet performance kit stage 1
Post by zero9243 »
Depends on what kind of modifications you have. Stage 1 is for stock engines and claim to give a performance increase, but you wont notice anything if all you change is the stock jets to the dyno jet stage 1
Upgrades:
3LK1-FZR wrote:has any body here used one? any noticable results? im thinking about installing it on my FZR 1K but want a few opinions first.
3,
If you are cracking open your carbs look at the emulsion tube FZR's are renowned for having poor quality ones and you should check to see if your have worn to an oval
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
3,
The worn emulsion tubes are usually noticed in poorer gas mileage
Upgrades:
3LK1-FZR
Post by 3LK1-FZR »
never heard about the emulsion tubes being bad. but is the kit worth the money? my only mods are a k&n box filter and a vance & hines slip on.
zero9243
Level 8.5
Level 8.5
Post by zero9243 »
3LK1-FZR wrote:never heard about the emulsion tubes being bad. but is the kit worth the money? my only mods are a k&n box filter and a vance & hines slip on.
if by box filter you mean one that drops right into the airbox a stage 2 might be what you want to try, Since the engine is now experiencing a little difference from stock.
Emulsion tubes are $100 for nikel plated ones that wont wear down. It depends on you if its worth the money.
Upgrades:
3LK1-FZR
Post by 3LK1-FZR »
yes i have the K&N that goes into the stock air box.
sweekster
Post by sweekster »
It's pretty much drop in (jets and needles), synch/tune, and go play. I'm running Factory Pro Stage 1 jetting in my 94 1k also with a K&N and the airbox. They aren't much different with the exception of the how the jets are numbered and the design of the needles (check the wiki for more detail on the differences).
3LK1-FZR
Post by 3LK1-FZR »
i just looked at the factory stage 1 kit and i think i will order it tomarrow.
