Fuel dumping out of carb overflows?
matt87
Post by matt87 »
Alright so I got past my clutch plate chatter by adding lock-tight and retightening the spring bolts. So I thought it was time to ride but as soon as I put it to run and the fuel pump started to kick on fuel dumped out of the carb overflows. This happened once before and I replaced all the lines and fuel filter and it was fixed. However, this will not stop and I have even started the bike thinking it might just be flooding the cylinders or something and it was still a steady stream from the carb overflows even with the bike idling normally? Any ideas? Anyone want to buy my bike?!?!?!?!
haro504
Level 7.5
Level 7.5
Re: Fuel dumping out of carb overflows?
Post by haro504 »
i would say yourfloats are stuck down and not rising to sut off the fuel
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
Try some seafoam to unstick the floats.
haro504 wrote:i would say your floats are stuck down and not rising to shut off the fuel
Sounds about right, Tap each float bowl solidly with a screwdriver handle (bout the only thing that will get round that space)
If theat does not work take the tank cover a& tank out and squirt seafoam as Darrin suggested down the inlet line. Run the engine till she dries out.
Then put the tank back hook up and test
