Steering stem bearing removal
20Valves85
Post by 20Valves85 »
Does anyone have a method of removing the lower tapered bearing and race removal without the special tool bearing puller? Any homegrown method? Thanks...
Huckleberry
100+ Posts
100+ Posts
Re: Steering stem bearing removal
Post by Huckleberry »
i would just take it to a machine shop. The cost would be very minimal.
bweight
Level 4.0
Level 4.0
Post by bweight »
Dremel? lol.. I dunno to be quite honest.. it's on the list of things to do as I've got a new bearing set on the way as well..
Haven't even looked at it quite yet, but if I find a way, I'll let you know.
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
reelrazor
Wrench
Wrench
Post by reelrazor »
Chisel.
If you are replacing the bearings...break the roller cage and get down to the inner race. Then chisel underneath/between race and tree. Hit it in a few spots. It should lift enough to start driving it off.
If you have access to oxy/acet or oxy/propane just cherry it and cut it.
juisii
Post by juisii »
Just few days ago I made a bearing replacement in the "Razor" style. Worked perfect ! Just have to remember file down the scratches from the axle... :whistle In case the chisel slips :hyprocrite
