lost air intake tube..
The Usual Suspect
Post by The Usual Suspect »
1993 FZR600- The fairing to frame air intake tube blew off on the freeway the other day. Is this an important ting? I don’t have an air box on my bike. It has a KN twin pod filter set up. Can I run it without the tubes?
I AM SUCH A YAMAWHORE!
1993 FZR600
STOCK I GUESS...
tkclow
Level 5.5
Level 5.5
Re: lost air intake tube..
Post by tkclow »
yes you can.
92 FZR600
Dual Headlight Upper Swap
Clear Taillight w/LED Bulbs
More To Come
PIMPMYFZR
Post by PIMPMYFZR »
man i wouldnt run the bike more then about 5 min with the thing on there ..
jk
it might get better air going into the frame now IDK
but you be more then fine without it on
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
It's little more than cosmetic, I wouldn't sweat it.
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
It has little to no effect on the bike. As a matter of fact, mine ran better without them. Odd too, because I didn't think they did anything - fact is, at higher speeds they create a little blip in my throttle response.
Plus, I couldn't use them due to my stabilizer being in the way:
BMiller wrote:The "frame coolers" do nothing.........take the other off too.
ERR,
not quite true in cooler climbs they just give about a1degree air temp drop round the outlet , however at higher temps and speeds they do add to the cool air round that part of the engine and carbs which does have effect on engine efficiency.
As most of you have noticed it is not a lot and may just be noticeable at 80Mph in Arizona summers
Fartblood
Level 4.5
Level 4.5
Post by Fartblood »
I think the fact that similar versions of the engine, such as the FZR600R, Fazer 6 and the Chundercat, do without them from the factory demonstrates how useful Yamaha themselves think the are. If a bit of plastic costing 50p to manufacture produced any worthwhile benefit then I think Yammy would've jumped at the chance to include them on the Fizzers offspring.
mossy1200
Level 5.0
Level 5.0
Post by mossy1200 »
ERR,
hi George .I think they would work better if they were aimed at the carb bowls to keep underside of tank and petrol in carbs cool.
Im thinking of geting a tube underneath with lots of small holes facing upwards and the end blocked off like a sprinkler pipe.
i have heard hot carbs and tank can cost 5hp.What do you think?
CaptainCanuck
100+ Posts
100+ Posts
Post by CaptainCanuck »
I think a heatshield might be more benificial. I just put one on my old gsxr ,but haven't tried it out yet. What do you guys think?
