r6 swinger wheel info/ whats a good 520 chain to use
- ghettomedic505
will a 01 r6 wheel fit an 03-05 r6 swinger??? help please
Last edited by ghettomedic505 on Sun May 03, 2009 10:23 pm, edited 2 times in total.
OH I THINK I DROPPED MY MONKEY
Re: r6 swinger wheel info
Not as a straight swap. You would need some custom spacers and bushings I think mainly do to axle differences.
- ghettomedic505
where would i be able to get the info i would need to do itcad600 wrote:Not as a straight swap. You would need some custom spacers and bushings I think mainly do to axle differences.
- ghettomedic505
so any one want an 01 r6 rear wheel with rotor hub sprocket and tire ha ha
If this was 4 weeks ago, I could have ripped both models apart and given you dimensions. But Mark sold his bike and Billy is a little busy to rip the rear of his apart right now.
If someone else has these parts, they could provide you dimensions of things. Beyond that, you would need to start buying some things and measure them to see what the differences are. I would start by buying the rear axles and try to find spacers as well. They would be the cheapest. You might be able to swap bearings in the wheel to cope with the axle differences, but don't quote me on that.
Do you have any parts right now? Why are you wanting to use a 99-02 wheel (to keep the 3 spoke?)?
GM,ghettomedic505 wrote:so any one want an 01 r6 rear wheel with rotor hub sprocket and tire ha ha
if the axle on the bike is thinner than the R6 one asimple sett of spacers is easy to make there are at least 4 guys who are capable of doing this work for you on this list.
Failing that a quick troll round the nearest industrial estate must find a machine shop and then it is time to make anew best friend with the lathe guy whilst holdin a almost concealed bottle of JD or JB
- ghettomedic505
YA I HAVE THE THE 03-05 SWINGER AND SHOCK ALREADY, WANTED TO USE IT FOR THE 3 SPOKE SO IT WOULD MATCH
Just pick up the axle and spacers for the 03-05 and take some measurements. It should be close.
By the way, the rear wheel if interchangeable up to the current model year R6S. So you don't have to look only for 03-05.
- ghettomedic505
If your going to give it away Ill take it!
- ghettomedic505
trade you??95FZR600 wrote:ghettomedic505 wrote:so any one want an 01 r6 rear wheel with rotor hub sprocket and tire ha ha
What do you want to trade? Not my new bike!
- ghettomedic505
- ghettomedic505
so will your shock mount still work on the swinger i have
