Flushing Radiator
Deputy1042
Flushing Radiator
How difficult is it to flush to radiator before refilling it with fresh coolant? It's on my to do list before getting the bike back on the road and if I can do it myself opposed to having the dealership do it, I'd like to save the money.
Re: Flushing Radiator
I would imagine its very easy, unhook the line from one side of the radiator and put a hose in it and turn on the water!
atleast, thats what I am going to do to my 60
SOLD
SOLD
flushing a radiator is easy. drain the coolant out into a bucket or container so it can be recycled. Then you can put a hose into it to rinse out the remaining little fluid in there. i use a small bottle of prestone system flush when working on a bike that hasn't had regular maintenance done to it. then flush a time or two with hose water and then once more with deionized (preferred) or distilled water. then close the system and fill.
..........................................................shitf.............................c3po...................next.victim............................................................
to see some of my ride videos, click the link: http://video.google.com/videosearch?q=b ... oogle.com#
may 2009: my 88 fzr 400 sets a speed record at the maxton mile: http://www.youtube.com/watch?v=GlOk-6aUsKc
FWIW if the coolant is newer, it can go down the sewer now, they all have to be safe for that now.shift wrote:flushing a radiator is easy. drain the coolant out into a bucket or container so it can be recycled. Then you can put a hose into it to rinse out the remaining little fluid in there. i use a small bottle of prestone system flush when working on a bike that hasn't had regular maintenance done to it. then flush a time or two with hose water and then once more with deionized (preferred) or distilled water. then close the system and fill.
if you aren't sure of course, get it recycled!
SOLD
SOLD
Deputy1042
Got'cha...I have no idea where I put my Clymer's which is why I asked. Do I have to take off the gas tank cover to get at the radiator to flush/fill it?
you can dump it in your sanitary sewer depending on local laws (if your area is equipped to decontaminate etheline glycol) but obviously not the storm sewer! (just to make that clear so people aren't dumping coolant into the street sewer --haunter wrote:FWIW if the coolant is newer, it can go down the sewer now, they all have to be safe for that now.shift wrote:flushing a radiator is easy. drain the coolant out into a bucket or container so it can be recycled. Then you can put a hose into it to rinse out the remaining little fluid in there. i use a small bottle of prestone system flush when working on a bike that hasn't had regular maintenance done to it. then flush a time or two with hose water and then once more with deionized (preferred) or distilled water. then close the system and fill.
deputy, i believe the 600 is like the 400 (which i have) so i would say yes, you have to remove the tank cover to fill the system. the drain should be on a metal line on the front left of the engine.
why does this smiley crack me up???
89 fizzerator
Yea, the radiator cap sits at the front of the triple right underneath the tank cover. It's secured at the 'V' in the front of the frame.Deputy1042 wrote:Got'cha...I have no idea where I put my Clymer's which is why I asked. Do I have to take off the gas tank cover to get at the radiator to flush/fill it?
Just remember. Wherever you go, there you are..
