Page 1 of 2
reusing spark plug?
Posted: Mon Jan 12, 2009 10:42 pm
by shredex
some of you may know that I have killed a few spark plug because of my leaking gasket....
I was wondering if I let the plug sit long enough to dry out, it they would be reusable??
Re: reusing spark plug?
Posted: Mon Jan 12, 2009 10:54 pm
by 95FZR600
I always light them with the lighter to dry them off and then put them under the wire wheel. Make sure you set the gap and try them.
Posted: Mon Jan 12, 2009 11:07 pm
Yeah what Mark suggested is good so try that first. But if you have 5 or 10 bucks head to Advance or pepboys and get autolite 4303's. I'm actually running champions in my 1000 and they are fine. It's not really a requirement to run the NGKs. Plus they cost too much.
Posted: Mon Jan 12, 2009 11:12 pm
by shredex
sweekster wrote:Yeah what Mark suggested is good so try that first. But if you have 5 or 10 bucks head to Advance or pepboys and get autolite 4303's. I'm actually running champions in my 1000 and they are fine. It's not really a requirement to run the NGKs. Plus they cost too much.
I just have like 3-4 plugs that all fawled in the same two months in the same head...
so they were just flooded..
if I can re-use them, then that would be great.
my second head plug went out yesterday
its nice to see something than the first head going out...
the other 3 have never gone out...I have never changed them since I bought it...(sept)
Posted: Tue Jan 13, 2009 8:57 am
by R3TARD
Gasket? I would have taken that money spent on a tank or other r1 stuff and got my motor straight first. Nothing sucks worse than having sweet looking bike sitting there with a bad motor
Posted: Tue Jan 13, 2009 9:31 am
shredex wrote:some of you may know that I have killed a few spark plug because of my leaking gasket....
Shredex,
Put them in the oven (NOT microwave) at a LOW temp and dry them out.
Yo will then need to clean them of soot with a steel or brass brush. Use them before relying on them as a back up set.
Posted: Tue Jan 13, 2009 8:56 pm
by shredex
yamaha_george wrote:
Shredex,
whats a low temp???
like 100 F?
Posted: Tue Jan 13, 2009 10:30 pm
by slayermd
shredex wrote:yamaha_george wrote:
Shredex,
whats a low temp???
like 100 F?
Whatever temperature you bake your cookies at.
Posted: Wed Jan 14, 2009 4:52 am
Shredex,
whats a low temp???
like 100 F?
No idea as to what actual degrees, I just put the Madams oven (NOT while she was around !!) on to the lowest it would go, leave for about 1/2 hour and pull them out . They are definitely too hot to handle for quite a while :-}
Posted: Wed Jan 14, 2009 6:55 am
by 95FZR600
The lowest I can go on a digital oven is 200 degrees.
Posted: Wed Jan 14, 2009 8:34 am
95FZR600 wrote:The lowest I can go on a digital oven is 200 degrees.
considering what they see and shunt in the way of heat on our bikes that should be ok.
In your place i would try ONE and see the result. As I said use a steel but preferably a brass wire brush (used for cleaning suede shoes etc) to clean the plug AFTER being cooked as the soot crap will be brittle not gungy.
Please take photo's of a before afterwards so we can add this to the WIKI as a FACT rather than as I have it as a guestimate.
Just think you can be a famous author :-}
Posted: Wed Jan 14, 2009 9:04 am
by DEMORAL1ZE
call me crazy but just go get some more...........what, they are like a whole dollar
Posted: Wed Jan 14, 2009 9:37 am
DEMORAL1ZE wrote:call me crazy but just go get some more...........what, they are like a whole dollar
D,
you had better tell us where you get your plugs from.here in the UK they are 6UKP (8.75 USD) EACH for the medium quality ones and about 8+ UKP for the precious metal versions.
I did mention that (in a previous post) they could be used as emergency back-up set after gapping & testing..
Posted: Wed Jan 14, 2009 10:06 am
by shredex
they cost $5 for the NGK CR9E/CR8E.
so why spend $20 when I can reuse the old ones and use that $20 for something I could use like gas and parts to finish the USD fork swap and so on.
I dont make enough to just go out and keep getting all this new stuff.
i work 4-10 hours a week at $8/hr
George, I will try it with one plug and see how it turns out.
Iv got a wire automotive brush that I can use to scrap it
Posted: Wed Jan 14, 2009 10:41 am
shredex wrote:DEMORAL1ZE wrote:call me crazy but just go get some more...........what, they are like a whole dollar
THNX Shredex
