Rear brake banjo bolt
Hardhat_harry
Can someone tell me if the rear brake banjo bolts has a fine thread, it's for an fzr400 3en2 but I would imagine the fzr600 is the same. I'm away at the mo so can't check for myself and I want to order all the parts I need to complete the bike so they are there when I return. I'm missing a hydraulic brake switch as I'm fitting racing rearsets ta
Re: Rear brake banjo bolt
Yamahas are pretty much universal at M10x1.25 for banjos.
If you're putting in toys and fancy hardware, consider this banjo ring-style switch (on the left). This will allow you to use a double bleeder-banjo bolt and a Speed Bleeder (note the comment about Yamahas needing extra washers). Your sanity will thank you.
Hardhat_harry
Cheers, part ordered and on it's way
