The day started like this - remove panels, drain fuel.
And ended being a total strip and clean of the carbs, some reworking of the cabling, and a lot of minor corrosion removal!
Oh... and a few dozen spider remains (and a couple of living ones!) removed
PICS!
Thats gotta pinch...
And when you get this close, you have to take a piccy!
Before....
A little tweak here...
...And After!
A quick scrub of all that spottyness.
And back in they go.
And with her all back together, and the plugs cleaned, the earth points all shiny and the HT leads serviced... and she's still only firing on 3
Not sure when i'll find another day to do a little more exploration, but im guessing its electrical. I reckon it may be a faulty plug or a corroded connector somewhere, i am borrowing a laser temp gauge Monday so i should be able to work out which cylinder is the faulty one. Still, worth the effort and a day in the garage. Its a healthy step in the right direction.
