I did all of this because when I got it running, after sitting for a couple months, it ran really rough & choked out easily. After I have done all of this, I can't even get it started!
Any help?
DonTZ125 wrote:Ummm ... sure. What bike are we talking about?
I did check all of those things except pulling the plug out again...as far as the mixture goes, I have no idea how to tell if it's even remotely correct. When it was running rough I turned the screw until it ran good, then when I cleaned everything, when it did turn on the idle was sky high, so I dialed it down with the screw, but it died and won't restart again.DonTZ125 wrote: If you've tried 20x to start - especially if this is a stroker - pull the plug back out to check you haven't fouled it. Is the plug cap on the plug? Is the plug cap firmly attached to the wire? Is the kill switch on? Is the mix ratio correct?
Is this a recoil start, or kick start? If it uses a clutch and gearbox vs a CVT, try push starting it.
