-new clutch cable
-cleaned carbs
-new chain/sprockets
-new brakes
-new tires
-new fork seals
So, first thing I noticed about this bike is that it has a whiny transmission. I learned that this is fairly normal for these bikes (straight cut gears).
Next that I'm trying to find out is the lurching, pulsing, or bouncing transmission. Those are the only words I can think of to describe it. Only happens in 1st and 2nd gear when I'm starting (low rpms) or just rolling forward. I feel like my tranny bounces in and out of engagement. Like my primary chain is rubber. My final drive chain is new, lubed, and tightened to specs. I have synthetic blend oil. Occasionally it's accompanied with a deep rattle, but just for a second.
Not sure exactly where it's coming from because I can't duplicate it on a stand. It has to be under load it seems like.
Do these bikes have issues with timing/cam chain tensioners? Or do these symptoms relate to the actual transmission at all?
Thanks ahead of time for the help!
