need advice
Re: need advice
Not normal unless somethings loose. Where is the rattle coming from? Is your bike an exup with the stock header? Could be the valve needs service.
Re: need advice
carbs out of sync make it sound worse than it is,.... just a thought
Re: need advice
Cam chain tensioner? Carefully remove bolt (it's undrr spring tension) and gently press a screw driver down onto tensioner just GENTLY and see if it will drop down a click. Might sort out the rattle.
Fzr400 3tj x2
'94 cbr 900rr
'94 cbr 900rr
