difference in years of farrings
cntryboy85
Level 3.0
Level 3.0
Post by cntryboy85 »
i am looking for all new farrings for my 95 fzr 600. i am going to be doing a complete body rebuild after i do the 660 conversion. does any one know if i can use the 89-94 plastics on a 95 or are there differences in the bodies?
cntryboy85
Level 3.0
Level 3.0
Re: difference in years of farrings
or if the FZR400 fairings will fit to the same year FZR600?
Harrysf707
100+ Posts
100+ Posts
Post by Harrysf707 »
As far as I know, any year FZR600 fairings will fit. As for the 400 fairings, I don't think they would.
The '91-92 had the single headlight, with the associated birdcage and upper fairing. I believe the side and belly panels were all the same.
sweekster
Post by sweekster »
DonTZ125 wrote:The '91-92 had the single headlight, with the associated birdcage and upper fairing. I believe the side and belly panels were all the same.
Correct. Side panels and tail are the same size for all years
Harrysf707 wrote:As far as I know, any year FZR600 fairings will fit. As for the 400 fairings, I don't think they would.
Correct. 400 is smaller so the panels don't fit (unless one wanted to get creative)
cntryboy85
Level 3.0
Level 3.0
thank you that was what i was looking for. i had found a set of 400 for pretty cheap but wanted to check first.
cntryboy85
Level 3.0
Level 3.0
also with other years were there models that offered a separate belly pan or was the belly pan molded in with the side pan?
