Debrix valve damper
JasonRDfan
Debrix valve damper
Post by JasonRDfan »
Who has bought the debrix valve damper? Supposedly it works as well as racetech's emulator. I think I will order one tomorrow. http://www.debrix.com/41mm-Fork-Damper- ... m?CartID=1
twack
Re: Debrix valve damper
Post by twack »
dont we need 38mm not 41?
JasonRDfan
From my understanding the inside damper rod is the same size. So this one should fit ours. I have found this information on the archives and a sv forum. This one also fits a gen one sv650 which has the same inside damper rod.
Yes, but if it doesn't fit inside the 38mm fork tubes, it doesn't matter what size the damper rod is ... :headscratch:
JasonRDfan
I will try to find the posts at the Archives when they where talking about it. I believe they said it fit.
JasonRDfan
Ok here is the link to the archives
http://www.fzrarchives.com/ipb/index.ph ... opic=54771
JasonRDfan
I recognize a couple of names posting over there. I should have opened a topic discussing these first on this forum. I did not find anything here about these. Someone just posted about a group buy for the UK. Anyways it looks like a cheap alternative for gold valve cartridge emulators.
JasonRDfan
Anyone? Come on people!! I know someone bought these! Lol I need to know if you like the quality? Any problems?
Genesis
Level 8.0
Level 8.0
Post by Genesis »
Hmmm. Not sure of that one mate.good luck
My FZR6 Rebuild
JasonRDfan
People over at fzr archives have been using it, that's why I posted a link to their messages. I just wanted to know the quality of this brand? Seems like a sweet deal right?
JasonRDfan
Cool, so I just found this, sv650 gen 1 has the same size fork damper rod and internals as a fzr 600. I just sold my sv650 gen1 about a month ago. So I just found this write up on the sv page.
http://www.svrider.com/forum/showthread.php?t=167329
buzzawak
Post by buzzawak »
I have recently installed the Debrix valve in my fzr400/600. Yes they fit our 38mm forks. What else would you like to know?
JasonRDfan
I just wanted to know if it was worth it or should I buy racetech's brand.
buzzawak
Post by buzzawak »
JasonRDfan wrote:I just wanted to know if it was worth it or should I buy racetech's brand.
The only difference between the two is you have a choice of 3 valve load springs when buying the racetech stuff.
I wouldn't be surprised it they both came from the same Chinese factory.
Makes a world of difference to how the forks work. I would also recommend getting some stiffer fork springs at the same time.
So much easier to do a whole rebuilt while the forks are apart.
Pair of 41mm Harley cartridge emulators inc postage $82.39
0.85kg/mm Sonic brand fork springs inc postage $119.00
Seals and Bushers inc postage inc postage $50
Snap rings $22
Fork oil $18.00
Total to me in Australia = $291.39
A bit of powder coating and new forks.
buzzawak
Post by buzzawak »
Figured I would get the rims powder at the same time.
