Who's got the Fattest tire or tyre?
FasterThanUr
100+ Posts
100+ Posts
Re: Who's got the Fattest tire?
Post by FasterThanUr »
Pilot road 2 160/60/18 on the stock fizz400 swinger
Pilot power 180/55/17 on my cb750 rr K6
Ok the honda's not done and lacking the swing arm,but that will be the tire on it.lol :banana:
90 FZR400/98 Fzr600 engine
Tom Tom GPS
05 R1 passanger pegs
03 R6 tail
O5 R6 radiator
07 R6 rear shock
97 YZF 600 carbs
Daytona stabilizer
I hooked my brake light switch to my throttle,so when I hit the gas everyone would slowdown and I would be gone :headbang:
abs929cbrrr
Post by abs929cbrrr »
its the angle, the rear is stright. my buddies gsxr600 rear is tweeked thouh, his is about 1/2" off.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
chefen2006
Level 3.5
Level 3.5
Post by chefen2006 »
Pirelli 180 when it was new
RCPlayland
Post by RCPlayland »
ShogunTX wrote:Ok other than looks what is the advantage of the bigger tire? This will possibly be material for the WIKI
Well I that a larger tire will take away from quicker turning.... a wider wheel will make it longer (time wise) to lean the bike into the turn. This probably won't be noticeable to average or sunday rider. But for you more aggressive riders you will probably notice longer reaction times when going through chicanes and such.
http://www.myspace.com/rcplayland <-------Click here for myspace webpages of me
mossy1200
Level 5.0
Level 5.0
Post by mossy1200 »
Hi guys
my opinion is the tyre choice doesnt effect the handling in the way most people look at it.
If you take a 5.5inch rim and put at 170 tyre on it the width looking at the rear end doesnt change alot.What does change is the contact pad on the ground surface.The 170 tyre will have a even footprint at all angles.
Next if we move to 180 tyre on same rim the width remains only couple of mm wider instead of 10mm.What changes more is the tyre gets pulled in more than the 170 tyre.This means less rubber when bike upright.As you lean the footprint becomes larger than the 170 tyre hence more grip on extreme lean angles.
Next if you were to squeeze 190 on the rim(which goes on ok trust me)the contact patch gets even less when upright but now the tyre is wildly distorted and you have to get the lean angle beyond safe operation of the tyre to get the even larger footprint.Therefore the 190 is not a good choice as it may work great arround corners for a while but if you consistantly get it over to the big footprint you will come of at some point.Its a game of chance and probability.
I think that until you get well out of the recommended tyre size for a rim the width that you look at the back of your bike does not alter to much.its the rim that dictates the width.This is my version of tyre width with low profile 55 tyres.
If the profiles were taller the width would change more.
Tip in times are not effected by tyre size as much as rim size and tyre type.(v tyre as oposed to d tyre).D being round and V being pointed sports tyre.
Then again I could be full of it.Please let me know.
