difference in years of farrings
- Level 3.0
i am looking for all new farrings for my 95 fzr 600. i am going to be doing a complete body rebuild after i do the 660 conversion. does any one know if i can use the 89-94 plastics on a 95 or are there differences in the bodies?
- Level 3.0
Re: difference in years of farrings
or if the FZR400 fairings will fit to the same year FZR600?
- Harrysf707
- 100+ Posts
As far as I know, any year FZR600 fairings will fit. As for the 400 fairings, I don't think they would.
1993 FZR 600 w/ 92' front fairing swap, 520 conversion, Yoshimura R&D Exhaust, RaceTech springs.
The '91-92 had the single headlight, with the associated birdcage and upper fairing. I believe the side and belly panels were all the same.
Correct. Side panels and tail are the same size for all yearsDonTZ125 wrote:The '91-92 had the single headlight, with the associated birdcage and upper fairing. I believe the side and belly panels were all the same.
Correct. 400 is smaller so the panels don't fit (unless one wanted to get creative)Harrysf707 wrote:As far as I know, any year FZR600 fairings will fit. As for the 400 fairings, I don't think they would.
- Level 3.0
thank you that was what i was looking for. i had found a set of 400 for pretty cheap but wanted to check first.
- Level 3.0
also with other years were there models that offered a separate belly pan or was the belly pan molded in with the side pan?
