guy i got my 929rr off stripped the paint of the rims on the lips and on the front one there is some white crap on the aluminum. can i get it off? what causes it? i think the bike might have been kept in a damp place or somthing because i found more other bolts with the same corrion on them...i want to replace them if i cant clean it off.
thanks
corrision on aluminum rim lips, can i remove it?
- abs929cbrrr
- 1000+ Posts
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
Re: corrision on aluminum rim lips, can i remove it?
yeah thats oxidation....sand it off!
SOLD
SOLD
- Fizzinatorr
- Level 6.5
once you remove it, seal it.
I have used some graffiti wipes from work and it seems to work wonders on stuff like that.
- abs929cbrrr
- 1000+ Posts
anything like air craft stripper work? i wanna strip the entire lip on the front rim he just did the edge.
aircraft stripper works wonders should work just fine thats what you use to strip anodizing from aluminum, just be careful that stuff will eat anything
- megaloxana
- 2000+ Posts
I got most of mine off with some mothers mag polish and stainless steelwool
'92 FZR 600
If you can try take tire off. Will make it much easier. Then tape the wheel up to where you want the line . I used small strips off tape but I striped the whole thing as much as I can unless you have airtools forget about gettin it fully polished ! Lol I didn't have no air tools! But just tape it good so you have a nice straight line
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
