When riding normal and also when applying the front brake, the bike rides straight and normal. When I apply the rear brake I get the sensation that the rear wheel shifts over like an inch then continues going straight. Now this is what I'm wondering, That my wheel was mis-aligned when I put new brake pads on the rear, right before going on a 1,600mi road trip and i think they wore in wrong. I just finished setting chain tension and aligning the wheel and i still get that sensation. If you guys do agree that it is brake pads that have been worn in with a slight "Slant" to them, do you think gentle pressure and use of the brake should be used until it wears even?
