weave & wobble
weave & wobble
This from another list but of considerable value here:-
---------- Forwarded message ----------
Date: 7 September 2010 13:25
Subject: Steering dampers - a warning.
To: USCRA@yahoogroups.com
Although hydraulic steering dampers can be useful in reducing the steering
kick back caused by bumps and dropping a misaligned front wheel on the deck
after a wheelie, they also have a dark side which is little known about nor
understood by the average rider.  There are no free lunches.
This is not a suitable forum in which to go into great technical detail, and
this is a very technical subject, so I shall try to keep it as simple as
possible.
There are two oscillatory modes of instability inherent in all inline two
wheelers.  Viz: Wobble and weave.
Wobble is a relatively low speed problem which shows itself as an
oscillation of the handlebars at around 30 to 40 mph.  Some bikes are more
prone to it than others.  e.g. The old 1960s BMWs with the Earles forks were
well known for this.  In general this is more an annoyance or curiousity
rather than a real danger and it can be easily reduced by the use of an
hydraulic steering damper.
Weave, on the other hand occurs at higher speed and has often resulted in
serious injury and many fatalities.  This form of oscillation involves the
whole machine not just the steering.  The bike will roll and yaw side to
side as well as the steering.  Whilst some bikes are known to exhibit this
behaviour it usually remains hidden until a particular set of conditions
sets it off, but ALL bikes have the potential for it to occur.
Unfortunately, a HYDRAULIC STEERING DAMPER INCREASES THE PROBLEM.  In simple
terms, the steering forces provided by the damper occur at a time that
reinforces the weave oscillation.  The forces are out of phase with that
required.
For those who are unfamiliar with just what a weave means I offer this link
to a dramatic video from the IoM.
http://www.youtube.com/watch?v=XiKmPFo6xNA
Here is a layman's description wobble and weave
http://docs.google.com/viewer?a=v&q=cac ... wEpjrqeWOQ
Here is a technical paper on the subject (not suitable viewing for maths
phobes - parental guidance advised)
http://eprints.imperial.ac.uk/retrieve/3175/license.txt
If WERA have mandated the use of steering dampers, then they are seriously
misguided if they believe it to be a general safety enhancement.  As I
stated at the beginning, it can be very useful to reduce the effects of
kickback and that can improve safety.  However, the characteristics of such
dampers is that they make a bike more prone to the very dangerous
possibility of weave.
This is a plea to the USCRA rules committee, to reject any future proposal
to mandate steering dampers under the misguided assumption that they are
always a safety feature.
If a bike shows no sign of kick back problems at a particular circuit then
you are better off to not fit a damper.  On the other hand, if the
handlebars try to fly out of your hands at times then a damper may be the
lessor of two evils.  Not all bikes need them, even on circuits like the
IoM.  I rode there for 5 years and never had one fitted.
Footnote.
There is some hope that in the future devices will be available to reduce
kick back, wobble AND weave.  Micro-computer controlled active systems could
do it, but there is a passive device which analysis has shown to have
positive effects with regard to damping out weave etc.  It has been called
an "inerta",  an hydraulic damper produces a force which is a function of
its compression or extension velocity, an inerta produces a force which is a
function of its compression or extension acceleration, which is 90 deg out
of phase with the velocity.
The reason that your neighbourhood MC shop doesn't stock them is two fold:
1.  It is only recently that their effect has been studied.
2. They are more difficult to impliment in metal than hydraulic dampers.  In
the past we had friction dampers because hydraulic items were too expensive,
so maybe in time we can hope that inertas may become common place.
As regards to dampeners, these were quite common in the days before tearoffs
to clean one's goggles.  They usually took the form of half a tennis ball
clamped to the handlebars, this contained a tethered sponge which had been
dampened before the race.  Their effect on wobble and weave was said to be
minimal, but they worked wonders removing the remains of insects impaled at
high speed.
Regards
Tony Foale
info@tonyfoale.com
www.tonyfoale.com
dougs
Re: weave & wobble
Post by dougs »
thanks YG have had big issues with this problem did not want to put a damper on as i havent seen any fitted to FZR's any way i found the problem elsewhere (front spring strength) cool info though cheers
FZR600R '94'
Bluespot calipers
Wavey front discs
R6 front mastercylnder
R6 lever mountings with short adjustable levers
YZF600R (thundercat) rear adjustable shock
Mild steel chain adjusters
Art can with removable baffle
Carbon fiber chain guard
Glass fiber rear seat-hump
Re: weave & wobble
dougs wrote:thanks YG have had big issues with this problem did not want to put a damper on as i havent seen any fitted to FZR's any way i found the problem elsewhere (front spring strength) cool info though cheers
Well glad you found out what it was.
just to add to the Knowledge bit of the thread:-
QUOTE
Honda have long known what Tony is talking about, even tho much of it is
over my head.  They developed HESD, "honda electronic steering damper"
which has been fitted i *THINK* to 2005+ 600 and 1000cc bikes as stock
equip.
The point of these things ? ok.  They feed off 2 things, engine RPM and
speedo.  They then apply varying force to the steering damper via a
variable system.  This means at low speed it is VERY loose.. such as
parking lots, driveway, etc.  The faster you go, the more torque, or
resistance is applied.  At over 100km/h its very stiff.  A mate who has
one fitted (cbr1000rr, 07 model from memory) poped his wheel up at
~100km/h and noticed its REALLY hard to move.  Quite a benefit.
Would something like that help elevate the issues you are talking about
Tony ?  At low speed its off, at moderate speeds its firm, and high
speeds its firmer again.  But im guessing with some electrickery, it
could be turned off, or vastly reduced at high speeds to suit the
chassis requirements ?
Would be interesting to get one from a wrecker and play around on a test
bench and see how it works and see what you can modify / reprogram.
http://0.tqn.com/d/motorcycles/1/0/Z/G/ ... R_HESD.jpg
