Can anyone ID this rear shock
thatkid
Post by thatkid »
Just found this while hunting in my junk, forgot i had it. When i got my 600 the MOT was due, the rear shock was covered in oil so i bought this off eBay, cost around £10. i think it said FZR750 rear shock, turned out the engine oil level was to high and spitting the stuff everywhere.
I've just checked the wiki "rear_shock_lengths" 600 is "11.938” eye to eye" this measures roughly 14.25" eye to eye, spring length is 9" approx (set on position 1), both eye's are 12mm approx. The top spring adjustment has 7 clicks, the lower damping adjustment has 30ish clicks (its stiff). I'm looking @ a R6 rear shock upgrade, but that wont be until next year, i may just try thro this on outa curiosity.
Re: Can anyone ID this rear shock
Post by sweekster »
I want to say it's a Genesis FZR750/1000 (87-88). The fishe doesn't give a good view of the bottom. I know that the bottom adjuster on my rear shock (which is an exup) is the same as that one.
Fizzinatorr
Level 6.5
Level 6.5
Post by Fizzinatorr »
Not FZR 400, Not FZR 600, not FZ 600 86, Not progressive, Not 88 FZ1000, not FZR1000, not fox, not ohlins, not white power...still looking
thatkid
Post by thatkid »
sweekster wrote:I want to say it's a Genesis FZR750/1000 (87-88). The fishe doesn't give a good view of the bottom. I know that the bottom adjuster on my rear shock (which is an exup) is the same as that one.
Fizzinatorr wrote:Not FZR 400, Not FZR 600, not FZ 600 86, Not progressive, Not 88 FZ1000, not FZR1000, not fox, not ohlins, not white power...still looking
Well i knew the best place in the world to ask. I was right. :cheers:
:udaman
