Should wires to ignition be hot?
The Usual Suspect
Post by The Usual Suspect »
I was doing some fine tuning on my 93 FZR600 with the tank cover off and engine running and when I toutched the wire hrness that connects to the ingition key switched i noticed it was petty warm. Not hot enough to say meltthe wire but it wat pretty warm. Is this normal? IDK
I AM SUCH A YAMAWHORE!
1993 FZR600
STOCK I GUESS...
R3TARD
Level 4.5
Level 4.5
Re: Should wires to ignition be hot?
Post by R3TARD »
Normally heat on wires is an indication of an electrical short. Sometimes a bad ground will also cause heat but if its your ign wires I would suspect a short
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
