YZf cylinder question Please help ASAP
China_Racer_1
Level 5.0
Level 5.0
Post by China_Racer_1 »
http://cgi.ebay.com/ebaymotors/Yamaha-Y ... 240%3A1318
Will these work on my 1999 yamaha YZF600R ?
I have a deal goinng on with Wiseco right now and the need cyclinders to bore out for a 2mm over for my race bike.
if these will not work does anyone out there have a set for sale?
Wiseco will buy direct from you on this.
Steve
cad600
Re: YZf cylinder question Please help ASAP
Post by cad600 »
yep they will work, and pm sent to you.
shredex
Post by shredex »
thats the same set i was gunnin for to do the 660 conversion...it just doesnt come with much...
if you can get it for $50, then that is appearently a awesome deal though!
and yes, it will work
China_Racer_1
Level 5.0
Level 5.0
I secured a set soon after posted. so go for it on the bid and good luck with the 660 convert.
Will let you know how it all turns out. So what if I do a 660 convert also and over bore 2mm hmmmmmmm?
Steve
shredex
Post by shredex »
China_Racer_1 wrote:I secured a set soon after posted. so go for it on the bid and good luck with the 660 convert.
Steve
Do it, Steve!!!
it will be more powerful than an r6 with the 660 conversion.
and I i found a whole parts motor with everything i need after seeing that...i was going to buy it till i got a $500 speeding fine...lol
it should only cost $60 to bore...i dont know how much the kit for the 2mm overbore is though...if you can do it, then do it. Appearently someone on here had the 660 with the 2mm over bore and he talked about who he raced and beat each day...donno
China_Racer_1
Level 5.0
Level 5.0
The deal have with Wiseco right now s they will provide me with 2 sets of customone off pistmns i na 2mm overbore and bore thheads hoentheme whatever as well as suply the gasketsneeded tojsut take off adn bolt on.
Ok excuse my ignorance but what cc wil I have if I do a 2mm over bore. i am stupid like that Ican never figure shit out like that.
Does that make it a 640 just by a 2mm overbore?
So with a 2mm over bore what will the 400cc bike jump up to a 440?
cad600
Post by cad600 »
Here is the formula:
displacement = (((bore x bore) /# of pistons) x 3.141593 x stroke x # of pistons) / 1000)
FZR400
56.00mm x 40.50mm = 399.01cc STOCK
57.00mm x 40.50mm = 413.38cc (+1mm bore)
58.00mm x 40.50mm = 428.02cc (+2mm bore)
59.00mm x 40.50mm = 442.90cc (+3mm bore = FZR600 pistons)
FZR600
59.00mm x 54.80mm = 599.29cc STOCK
60.00mm x 54.80mm = 619.77cc (+1 mm bore)
61.00mm x 54.80mm = 640.60cc (+2mm bore)
62.00mm x 54.80mm = 661.78cc (+3mm bore = YZF600 pistons)
YZF600
62.00mm x 49.60mm = 598.98cc STOCK
63.00mm x 49.60mm = 618.46cc (+1mm bore)
64.00mm x 49.60mm = 638.25cc (+2mm bore)
65.00mm x 49.60mm = 658.35cc (+3mm bore)
Hybrid FZR600 crank w/ YZF600 pistons
62.00mm x 54.80mm = 661.78cc STOCK
63.00mm x 54.80mm = 683.30cc (+1mm bore)
64.00mm x 54.80mm = 705.16cc (+2mm bore)
65.00mm x 54.80mm = 727.37cc (+3mm bore)
megaloxana
Post by megaloxana »
China_Racer_1 wrote:The deal have with Wiseco right now s they will provide me with 2 sets of customone off pistmns i na 2mm overbore and bore thheads hoentheme whatever as well as suply the gasketsneeded tojsut take off adn bolt on.
steve are you drunk? lol i dont have my decypher code ring with me.
cad600 wrote:Hybrid FZR600 crank w/ YZF600 pistons
^thats some crazy displacement ...is 3mm even possible without adverse effects?
'92 FZR 600
cad600
Post by cad600 »
Vance & Hines did it back in '92 with some custom pistons. They where competing with some bored out CBR600f2 for a magazine article. If I remember correctly, the bike did not finish the test as the motor destroyed itself.
Almost everything I've herd of for the FZR derived engine is that 1mm over bore is OK, but 2+mm overbore creates cooling issues. The only exception seems to be the 400 engine. The 600 was derived from the 400 engine so it would make since that there is a limit to enlarging our engines safely.
dru86
Level 1.5
Level 1.5
Post by dru86 »
Steve does Wiseco realise that the yzf600 bores are nikasil plated (unlike the cast iron bores of the fzr600) and that if they are bored the will have to also be re-plate? This is normally a rather expensive process which can cost about as much as the pistons themselves.
I've read a few times about rumours that if you overbore you will have "cooling issues" but have yet to hear from anyone who has actually overbored. I'm running the 660 which is the 3mm overbore with higher compression and the bike doesn't run any hotter than stock. Sounds like an old wife's tale to me.
cad600
Post by cad600 »
I think you're right about the plating Drew. But remember the YZF cylinders are different from the FZR and I'm not just talking about the bore. They were designed to work with the 62mm pistons. The cylinder sleeves are a different material and the cylinder itself has different water jacket lines to help with this. Weisco's own 2mm overbore kit for the FZR has well documented cooling issues.
Hey Shred - most shops charge $60 per cylinder bore. That would be $240 for the set. But I'm sure that where Steve is located, he can get a shop to do it fairly cheap.
