Anyone have a block jet (the part that holds the jets) assembly that I can buy. My pilot jet got stuck in the threads and I have chewed it up trying to get it out. Not that if I can get the jet out I couldn't use my old assembly but I would like a spare and just in case I jack the threads up trying to get the jet out.
It's part number 35 on the bike bandit website.
http://www.bikebandit.com/houseofmotorc ... #sch133379
Thanks,
Chris.
EDIT I should also put it's the stock carbs. Mikuni. Any carb set from 93 up will work.
Block Jet Assembly..
Forum rules
- kilika2
- 1000+ Posts
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
Re: Block Jet Assembly..
I got you covered bub! $20 shipped sound good?
- kilika2
- 1000+ Posts
Indeed it does. I'm going to try to get a new jet(I got the old one out after carefully drilling it out) at the stealership and then EXTENSIVELY clean the block assy. I might still get this from you. I will pm if I do need it. Thanks Nate.
Chris.
Chris.
1995 FZR600 Sold
2006 R1 Sold :-\
2009 Buell 1125R
