'91 driving light?
Forum rules
'91 driving light?
Anyone out there have access tothe little light above the headlight on the '91-'92 uppers? I believe it's a European spec part, I've heard it called a "driving light".
1989 FZR 600
Re: '91 driving light?
http://www.ebay.co.uk/itm/Yamaha-FZR100 ... 1007376433
I dont mind forwarding it overseas at postage cost if you cant access it from the states
Does that work with a US wiring harness? Or am I going to need some electrical engineeringto wire it in?
1989 FZR 600
I'm almost positive there is no connector on the US harness. Looking at the US and UK wiring diagrams in the Wiki, it's a matter of tapping into the bLue/Red wire at the key switch and the Black wire at the headlight. Without seeing the part or a good view of the harness, I can't comment on what connector you'll need.
