Hi Peeps, New to the site so be gentle with me!!, I've just acquired a 400 3TJ model, complete but a bit the worse for wear, and require the following parts to restore it to it's former glory, here goes : Swinging arm, standard end can, lock set ( or at least the rear set catch/lock mechanism, and the rear seat unit plastic panel (the bit the side panels attach to!).
If any kind folks can help with sourcing any of the above I'd be very grateful. Thanks for taking time out to read this plea BTW.
Thanks and best regards bezzer.
FZR 400 3TJ Parts required!
Forum rules
Re: FZR 400 3TJ Parts required!
that model was not imported to the states it is japan Europe only to the best of my Knowledge.
Hardware E-bay is your friend , on this site there is a UK based restorer " willandrip" he should know where to look outside of the fleabay.
Plastics i use Alkemoto the guys name is Alan and i have bought bits from him for most of my bikes first class service.
For fibreglass panel replacement bits I have used Skidmarks stuff with good results
PM SENT
PM SENT
Hi George, Thanks so much for your response, and useful information. I will look out for willandrip and see if he can help. I now realise I posted in the wrong section!!.
BTW I have tried to pm you to no avail, will try again.
Best regards bezzer.
No worries got your direct mail just about to do pictures.bezzer wrote:Hi George, Thanks so much for your response, and useful information. I will look out for willandrip and see if he can help. I now realise I posted in the wrong section!!.
L8trs
