Ignition Coils
Forum rules
Ignition Coils
Coils are all that's keepin my bike from coming to life I believe. Anybody got set they don't need for cheap?
Re: Ignition Coils
There is a swap I have read about using Ford escort coils..... or something like that. Not sure of specific's.
My FZR6 Rebuild
My FZR6 Rebuild
Re: Ignition Coils
Here is another option, I am thinking of doing this myself.
http://fzronline.com/wiki/doku.php?id=c ... _plugs_mod
My FZR6 Rebuild
My FZR6 Rebuild
Re: Ignition Coils
I can offer a plug'n'play harness, $50 + shipping.
Re: Re: Ignition Coils
For the Coil over plug swap?DonTZ125 wrote:I can offer a plug'n'play harness, $50 + shipping.
My FZR6 Rebuild
My FZR6 Rebuild
Re: Ignition Coils
Yes - it will plug into the stock harness at the two coil connectors, and then into the four COPs. The harness will come out between the #3 and 4 cylinders, then disperse from there.
Re: Ignition Coils
So what is the benefit of doing this coil swap anyway?
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
Re: Ignition Coils
Newer coils, don't need to worry about cracking plug cap resistors and rotting, corroding wires, frees up room under the airbox for other strange ideas.
Plus it's just COOL, man ...
Re: Ignition Coils
What years of a ford escort can i use?
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
YZF forks
YZF swingarm
YZF rear shock
"Chopped" rear end
Re: Ignition Coils
No idea - my reply to Genesis was regarding the CBR600 coils.
Thats cheaper than a harness on eBayDonTZ125 wrote:I can offer a plug'n'play harness, $50 + shipping.
My FZR6 Rebuild
My FZR6 Rebuild
Re: Ignition Coils
Ok - $75!
- for now ...
Re: Ignition Coils
They include coils though.
My FZR6 Rebuild
My FZR6 Rebuild
Re: Ignition Coils
91 and later as long as its fuel injected 1.9L or 2.0L. The 1.8L in the gts was a Mazda motor with a single coil and cap rotor setup. Its also the same coil used on the Mustang and other V8 Fords with the dual 4 pack coil packs. Msd and Accel make aftermarket versions for it as well. I may not have many bike answers yet but I've been building Fords for almost 25 years.desmarat wrote:What years of a ford escort can i use?
