Swingarm has a nice powdercoat job. Comes with the brake hanger, swingarm bearings and pivot shaft (not pictured). I may have a few other parts to go with it and I'll gather them all up. The pivot shaft has some wear that you typically see where the bearings ride on it. Also, I spent a good deal of time repairing the axle adjuster threads on one side because the previous seller failed to say that the adjuster bolt was broken off. I drilled out the bolt and Heli-coiled the threads. There is a little piece of the bolt that is rattling around inside the swingarm. Harmless, but I want the buyer to know. A steal at $135.00 shipped.
The forks are in excellent shape. Chrome looks good and they are straight and ready to bolt on. I took off the caps to check the internals and the oil looks fresh. Stock inside with what may be progressively wound aftermarket springs. No markings regarding spring rate. $110.00 Shipped
Link to ad with pics:
http://forums.13x.com/showthread.php?t=325566
3TJ Swingarm and 1WG forks
Forum rules
XR650R in an FZR400 chassis project
