Hi guys,
I have a few YZF 750 parts for sale, parting out my whole bike and some other stuff, as well.
Polished swingarm $150
YEC RPM Gauges $325
YEC Temp Gauges $150 -1 sold - 1 left
OW01 Sprocket cover / cable conversion $300 - Sold
Brembo 320mm Snowflake disks $550
Vance & Hines Full SS2R Exhaust $550
Vance & Hines Powerpak $200
Carbon Fiber tank/ quick fill / fuel pump $800
YEC Alternator covers $100 - 1 sold - 1 left
Falicon clutch basket (brand new) with gear $500
EBC SRK9 Kevlar clutch kit $150
R1 front axle conversion $30
R1 front brake caliper conversion $400
R1 rear brake caliper conversion $200
Vortex / JT 520 conversion sprockets $80
72.5mm oversize piston / cylinder combo $275
Rear wheel $100
6 speed YZF 750 transmission $200
6 speed YZF 750 transmission, very low mileage $300 - SOLD
Close ratio 6 speed transmission YZF750SP $600 -SOLD
YZF 750 headlight assembly $60
YZF 750 starter motor $50
YZF 750 speedometer, tachometer and temperature gauge assembly $120 (6348km only)
YZF 750 alternator, generator and rectifier assembly $75
YEC kill switch $50
Complete triple clamp $75
Lower triple clamp $25
Complete forks Racetech valving $500, standard forks $150
Clip ons $25 each / $40 for the set
Oil pan with level sensor $40
Clutch master cylinder RADIAL conversion $100
Front brake master cylinder RADIAL conversion $100
http://www.yamaha-yzf-750-parts-for-sale.com/
Yamaha YZF 750R 750SP OW01 YEC parts for sale
Forum rules
Re: Yamaha YZF 750R 750SP OW01 YEC parts for sale
Added:
Wiseco 77mm pistons (2 sets)
YZF 750 OEM cylinder / piston set 72mm
YZF 750 gas tank bracket
YZF 750 Factory Pro emulsion jets
YZF 750 clutch basket
FZR 1000 clutch basket
YZF 750 carburators with TPS and ECU
YZF 750 fiberglass upper fairing
YZF 750 fiberglass lower fairing (belly pan)
YZF 750 Airtech Tail section
YZF 750 Cylinder head assembly
kgreene110
Will the 750 stuff fit easily to the fzr 600 interested in the tail?
To my knowledge the tail sections are very similar if not exactly same, other than the color scheme. I believe it would fit.
Added:
Yamaha YZF 750 clutch basket w/out ring gear
Yamaha FZR 1000 clutch basket - slightly damaged
Yamaha YZF 750 camshaft set
Yamaha YZF 750 ignition coils
Intake manifolds
Harris modified rear sets for YZF 750
K&N filter
Curved Radiator with fans
Intake manifolds
K&N filter
Added;
YEC Keihin FCR 39mm YZF 750 carburators with YEC composite airbox - a must see
The price is listed on the web site, I'm asking $1300 for everything. Of course accepting offers, as well...
Have you still got any of this?
Thanks
Thanks
