FZR400 Motherload of parts
Forum rules
Locked
kneedragger88
Post by kneedragger88 »
Hi Guys,
New to the forum. I have a 400 racebike myself but am helping my late teammate's family liquidate his stock of racebikes and parts. Below is a partial list with bikes to follow. A little about me, I am the owner of SOAR a regional race series in Ontario,Canada been a racer from 87-08 now just some occational vintage stuff. All prices are in CAD with shipping extra, if you wish to bunch things and make an offer please send to info@SOARacing.ca and I will take your reasonable offer to the family.
Thanks for looking.
Number Description Ask
1 Complete 400 engine assume running NRC covers $700
1 Complete 400 looks stock street engine $700
1 Full stock exhaust system $75
3 FZR400RR Rear Wheels with rotors one with SC2 slick 17x5 $250
3 FZR400 Rear Wheels one with a like new rain 18" $0
3 FZR400 Frt Wheels with rotors one set needs buttons one with SC1 80% one BT090 50% $175
1 Pirelli Dragon MTR02 New 150/18 $100
1 Front steering pin stand w/two pins $75
1 FZR400 bottom end note says spun bearing but showing now rod play APE CCT $150
1 FZR400 bottom end with crank,rods,cases,tranny (cranks sell for $300 each) $450
1 FZR engine cases w/cyl studs empty $75
1 OEM FZR400 windshield w/small crack $5
4 Speedo (showing 27K,20K,15K,27K) $15
3 Rad overflow bottles $7.50
3 Speedo Cables $7
2 OEM FZR400 Mirror Left $12
1 OEM FZR400 Mirror Right $12
2 OEM FZR400 Headlight Assemblies $60
4 OEM FZR400 Signal Lights $7
3 OEM FZR400 Chain Gaurds $5
3 OEM FZR400 Rear Seats $20
2 OEM FZR400 Front Seats $25
4 OEM FZR400 Taillights $12
1 FZR400 Solo Seat cover small crack one tab missing but useable $25
1 FZR400 Solo Seat back pad for race seat $20
4 FZR400 Side Stands $7
2 OEM Early FZR400 swingarm with adjusters and brake stay arm $50
3 OEM FZR400 Gastanks no pumps $35
1 37mm Fork collar for damper $15
1 Unknown curved rad (looks ZX) with custom hoses and brackets likely modified for FZR $300
1 Acerbis race puke bottle $12
5 OEM FZR400 front fenders $30
1 SET OEM FZR400 Mid Panels with decals $75
1 Right OEM FZR Mid Panel repaired and repainted no decals $25
2 OEM FZR400 tank covers with decals $60
1 OEM FZR400 tank cover rashed with broken front tab repairable $30
1 Race FZR400 tank cover rashed and broken tab repairable $50
1 Race FZR400 tank cover complete $70
3 OEM FZR400 upper fairing $70
1 Fibreglass FZR400 Upper crashed but repairable $75
4 Race seat $75
1 Honda RS250 (looks 93plus) seat w/HRC seat pads $75
2 One piece lowers (run on higher side may mount to stock uppers) rashed $70
1 One piece lowers (lower rise likely for race uppers) rashed $70
1 Front end with polished lowers and lower triple clanp $200
1 06 CBR600 Seats front has three small cuts $80
2 Late OEM FZR400 Swingarms with stays and adjusters $150
2 Subframes $80
1 Subframe cut for race $60
1 Full header FZR400 not sure brand no can high rise for track use $200
1 Set OEM FZR400 Lowers complete with decals $150
1 FZR400 Clear LP Windscreen brand new $60
4 Stock airbox $750
1 K&N FZR400 Air filter $25
2 Uni FZR400 Air Filter $20
5 OEM FZR Frame connectors $5
1 OEM FZR400 shock $10
1 Unkown kill start switch (could be universal) $5
1 AIM Lap timer no becon been stored over five years lights right up $150
1 OEM FZR400 petcock $12
1 06 CBR600 Windshiels some scratches $15
1 Racetech FZR400 0,95 Fork Spring Kit Brand New $125
6 FZR400 Clutch packs some with steels some without some OEM some Barnett USED $45
2 OEM FZR Rear caliper with stay $30
1 OEM Rear caliper $12
2 OEM FZR400 Complete clutch baskets inner and outter $50
2 OEM FZR400 Shift Shaft $25
2 OEM FZR400 Water Pump $30
1 FZR400RR Sprocket carrier for 17" wheel $60
2 FZR400 Sprocket Carrier for 18" wheel $5
5 FZR400RR Rear Alloy sprockets 45,47,48,53,54 $15
2 OEM FZR400 Rear Steel sprockets $10
10 FZR400 Rear Alloy sprockets 40,42,43,47,47,48,50,51,52,52 $12
11 FZR400 Front sprockets 2x14 6x15 2x16 used 1x16 new $7,50
3 FZR400 Rear rotors fits 18" $10
3 FZR400 Cyl banks $75
4 Set stock pistons used but clean $60
3 OEM FZR400 Crankshafts $350
1 OEM FZR400 Transmission complete $100
1 OEM FZR400 Intakes with rubbers $25
1 FZR400 Rad Upgrade (believe its FZ750) $60
1 FZR400 Rad Upgrade (not sure of origin about twice a 400 rad and 25% larger than FZ750) $70
1 Very clean complete FZR400 head w/cams valves etc (NICE PORTING JOB) $300
2 Set OEM FZR400 camshafts $50
2 Sets aftermarket FZR400 Camshafts (don’t know brand or specs some etched numbers) Brand NEW $250
3 OEM FZR400 Fans $5
2 OEM FZR400 Oil Pans with Plugs $25
3 OEM FZR400 Clutch Covers w/Fill Caps $25
1 OEM FZR400 Timing Cover $25
4 OEM FZR400 Chain Cover $7.50
2 OEM FZR400 Stator Cover $25
1 OEM FZR400 Oil Filter Cover With hollow bolt $10
1 Race Tracksport Stator Cover rashed but solid $30
1 Race NRC Timing Cover rashed but solid $30
1 Race NRC Stator Cover rashed but solid $30
1 RaceNRC Timing Cover repaired but solid $30
1 Race Vance and Hines Stator cover used but clean $60
1 OEM FZR400 Rear brake stay and caliper carrier $5
3 OEM FZR400 Coolant overflow bottle $12
1 D & D Exhaust can rashed but usable $60
1 Hindle Exhaust Can rashed but useable (round) $60
1 OEM FZR400 head with cams $200
1 OEM FZR400 suspension link and dogbones $5
3 Sets Front steel braided brake line sets $60
2 Rear steel braided brake lines $20
2 Sets OEM FZR400 Front brake calipers $50
4 OEM FZR400 Master Cyl w/levers one with crash guard $50
10 Handlebar/Fork Collars $7.50
12 OEM FZR400 Handlebars $8
8 OEM FZR400 Clutch Levers (2 with perch) $5
1 OEM FZR400 Brake Lever used $5
2 Parts Canada FZR400 Brake Lever NEW $12
4 OEM FZR400 Intake Rubbers NEW $20
10 FZR400 Wheel Bearings NEW Brand Name $5
8 NGK CR8E NEW $3
5 Steel valve stems NEW $8
6 Rubber Valve Stems NEW $5
1 OEM FZR400 Timing Cover Gasket NEW $2
1 OEM FZR400 Oil Pan Gasket NEW $2
2 OEM FZR400 Chain Cover Gasket NEW $2
1 OEM FZR400 Cylinder Base Gasket NEW $2
3 OEM FZR400 Clutch Cover Gaskets NEW $2
1 OEM FZR400 Stator Cover Gasket NEW $2
1 Cometic FZR400 Stator Cover Gasket NEW $2
4 OEM FZR400 Valve cover gasket NEW $15
2 Barnett FZR400 Race Clutch Springs Sets NEW $25
2 Barnett FZR400 Race Clutch Springs Sets Used $20
1 Assorted seals bushings bearings small gaskets FZR all NEW approx $50 pces $100
2 OEM FZR400 Fuel Pumps $40
4 OEM FZR400 Rear Passenger pegs and mounts $10
2 OEM 06 CBR600 Rear Passenger pegs and mounts $10
12 OEM FZR400 Right Side Peg mounts $8
3 OEM FZR400 Rear Brake Pedals $15
7 FZR400 Pegs different brands all rashed $5
1 OEM FZR400 Speedo Drive $10
1 Woodcraft Peg (universal for all Woodcraft sets) $15
4 OEM FZR400 Fork Brace/Fender mount $10
1 OEM FZR400 Right Side Rearset Toe Guard $5
1 OEM FZR400 Upper Triple Clamp $40
1 OEM FZR600 Fan $5
1 OEM FZR400 Stator and Flywheel $50
3 OEM FZR400 Starter Motors $15
2 OEM FZR400 Wire Harness with CDI,Relays,Coils etc $75
1 OEM FZR400 Wire Harness only $50
1 OEM FZR400 Right Bar Switch assembly $20
1 OEM FZR400 Left Side Bar Switch assembly $20
2 OEM FZR400 Starter Selenoids $5
3 OEM FZR400 Clutch Cables $5
6 OEM FZR400 Throttle Cables $5
1 OEM FZR400 Choke Cable $5
~JM~
100+ Posts
100+ Posts
Re: FZR400 Motherload of parts
Post by ~JM~ »
Please check your PM's.
Thank you
~JM~
slickwill
Post by slickwill »
I'd like the petcock and new wheel bearings.
Is the price for the 18" rear wheels really supposed to say $0?
...dude you ride an offroad bike with slicks, 1/2 the weight of a GS, double the suspension, with a browning 50 cal going off 32" from your skull as a daily freaking driver - I'd expect anything except a nitro dragbike to be bland by comparison - SSG
slickwill
Post by slickwill »
Do you have any of the OEM bodywork mounting brackets and/or fasteners?
DAP019
Post by DAP019 »
If you have a fzr400rr wheel that is 17x4.5 i need one that will fit an fzr swingarm. Thanks, Derrick
~JM~
100+ Posts
100+ Posts
Post by ~JM~ »
I don't think this guy checks back on his Ad. You probably need to try his e-mail address that he has listed.
Good luck
~JM~
He's selling the parts for a friend's family, and hasn't been back since July. Like JM said, contact him directly.
bat333
Post by bat333 »
I have emailed him through all the places he has ads and no response. He needs to take his off those area or answer Emails.
Locked
